How to Fix Data Connection Problem in Android Mobile Issues with Ease
This post aims at telling you how to fix data connectivity problem on Android. If your Android phone is not connecting to the Internet, this post is exactly what you need.
By iMobie | Posted on: Apr. 03, 2018, Last Updated: Jun. 13, 2019
Cellar data, or mobile data is what you rely on to be able to browse a web or simply access WhatsApp or Facebook when you are some places where there is no Wi-Fi. Without cellar data, you won’t be able to get anywhere without Google Map or talk to friends on mediums via phone anytime you like. Unfortunately, data connection problem in Android mobile phone occurs to many users every day.
If you are encountering data connectivity problem on Android, don’t fret, even though there are so many reasons causing data connection problem in Android mobile, here in this post, we have summarized all potential fixes to solve Android phone not connecting to the Internet problem. Please keep reading and get more.
Don’t Miss: How to Backup Android Phone Data >
How to Fix Issues of Data Connection Problem in Android Mobile Phones
Here are some general troubleshooting tips for data connection problem in Android mobile issues. Please try them first.
– Check if your phone is out of service due to an overdue bill.
– Reboot your Android device.
– Turn on Airplane mode and off on your Android phone.
– Take your SIM card and make sure there are no obvious lumps of dust, then put it back.
These four general tips would fix majority of data connectivity problem on Android. If they don’t work on your Android phone, we have more solutions to help you fix data connection problem in Android mobile.
Tip 1. Fix Data Connection Problem on Android by Changing Mobile Data Limit
Every Android phone allows users to set mobile data limits and warnings when you are about to reach the limit. Maybe you have just reached the limit for the day. Under this circumstance, you can either try to enable the data connection the next day or change the limit with the steps below.
Step 1. Go to Settings > Mobile Data/Data Usage.
Step 2. A graph showing you data usage along with a bunch of settings would be displayed. Drag the limit up in the graph.
Step 3. You can also untick the “Limit mobile data usage” box to turn off all data limits.
Tip 2. Fix Data Connectivity Problem on Android by Resetting APNs
APNs, abbreviation of Access Point Names, are used to connect your mobile network provider with your phone. With APNs, your phone can be set up correctly to be connected. Here is how to reset APNs.
Step 1. Go to Settings > Mobile Data/Wireless & Networks/Wireless Controls > Mobile Networks > Access Point Names/APNs.
Step 2. A lost of APNs would be shown. Tap the menu icon (the three vertical dots), and tap “Reset to Default”.
Fix Data Connection Problem Android by Resetting APNs to Default
Tip 3. Fix Data Connection Problem on Android by Setting APN Protocol to iPv4/iPv6
The method may not work on all Android device. However, some users have reported that they have fixed data connection problem on Android with this method. Follow the steps below and you will set APN Protocol to iPv4/iPv6.
Step 1. Go to the APN list with previous tips.
Step 2. If the APN Protocol is on the option list, make sure it says iPv4/iPv6 instead one of them.
Tip 4. Fix Data Connectivity Problem on Android by Sending Your Android Phone to the Maintenance Store
If all methods above are not working, you can do nothing but to send your Android phone to the maintenance. If your Android phone is under warranty, it shouldn’t be a big problem.
Above are efficient methods to fix data connection problem on Android. If you have further questions about this guide, please don’t hesitate to leave comments below.
AnyTrans ® for iOS
  • * 100% Clean & Safe
11,452,517
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
