How to Check iPhone Text Messages Online Easily
Is it possible to view iPhone text messages when you don’t have your iPhone at hand? The answer is Yes. In this article, we’ll show you a simple way check iPhone messages on online.
By Tom Boyer | Posted on: Jan. 10, 2018, Last Updated: Mar. 06, 2019
Home > AnyTrans for iOS > iPhone Messages Manger > How to Check iPhone Text Messages Online Easily
When your iPhone is damaged or lost, your data is absolutely your first concern. With iCloud syncing feature, you are able to access your contacts, calendars, reminders, photos from other Apple devices or on iCloud.com. But what about your text messages that cannot be synced with iCloud? If you unfortunately run into such a disaster and is looking for a method to view iPhone text messages online, this is the right place for you.
Frankly speaking, your SMS messages are not viewable online. But if you have backed up your iPhone to iCloud, your text messages, of course, are uploaded to iCloud in form of backup data. Therefore, with iCloud backup, you can easily check iPhone messages online using AnyTrans for iOS – a handy iCloud backup manager.
The Tool You’ll Need to Use
In comparison to other iOS data management tool, AnyTrans for iOS is special in that it allows you to access your iCloud or iTunes backup and view your text messages, contacts, photos and other files in backup. With this tool, you are able to check text messages online even if you don’t have your iPhone at hand.
AnyTrans for iOS can work perfectly with both Windows and Mac OS. Now, download and install AnyTrans for iOS and follow the instructions to view text messages online.
How to Easily Check iPhone Messages Online with AnyTrans for iOS
Step 1 Open AnyTrans for iOS software. Click iCloud icon from the top menu bar and then log in with your Apple ID and password.
How to Check iPhone Messages Online - Step 1
How to Check iPhone Messages Online – Step 1
Step 2 Scroll down and choose iCloud Backup.
How to View iPhone Text Messages Online - Step 2
How to View iPhone Text Messages Online – Step 2
Step 3 Select your iPhone backup and download it. After download completes, click the View button to continue.
How to Access iPhone Text Messages Online - Step 3
How to Access iPhone Text Messages Online – Step 3
Step 4 Check your messages in iCloud backup. If you want to extract your messages from iCloud backup, select the messages you need and click To Computer to save them to your computer.
How to Check iPhone Text Messages Online - Step 4
How to Check iPhone Text Messages Online – Step 4
Anytrans can not help you check the deleted text messages. If you want to check and recover the deleted or lost messages on the iPhone, then you can do this by referring to this post.
With AnyTrans for iOS, you can view iPhone text messages on computer without plugging in your iPhone. It gives you access to iPhone files in both iCloud and iTunes backup and allows you to easily export messages or that other files from backup. Get a free trial version now >
Tom Boyer
A writer for iMobie, has been covering iOS, Mac and Android related How-to Articles / Apps Reviews for 3+ years. Like sharing something about data recovering knowledge and apps.
AnyTrans ® for iOS
  • * 100% Clean & Safe
11,452,517
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
