How to Turn on Low Power Mode on iOS 9
How to enable Low Power mode on iOS 9? Read on this guide and follow the steps to set up your iPhone/iPod touch/iPad to turn on Lowe Power mode to extend the battery life of iDevices.
July 23, 2015
PhoneClean – Clean Your iOS Device to Make More Room
PhoneClean – Best iOS Clean Software
Download this professional clean software to clean your iPhone/iPod/iPad all around to free up space and optimize the running speed of device. Then follow this guide to learn about how to use Low Power mode on iOS 9.
One of the outstanding features about the iOS 9 is that it allows users to enable the Low Power mode to extend the battery life when the iOS device is running low. The Low Power mode activates when an iOS device reaches below 20 percent battery. The battery will become a yellow icon instead of typical red one under 20 percent. Now how to turn on the Low Power mode on iOS 9? We will show you details to make it.
Also Read: Top 15 Tips for Saving Battery on iPhone iPad >
Step 1. Open Settings app.
Step 2. Scroll down to the new Battery item and tap on it.
Step 3. Slide the toggle to ON to enable Low Power Mode.
How to Turn on Low Power Mode in iOS 9
Image Credit: theibulletin.com
Note: Make sure you have updated your iOS devices to the iOS 9. More than anything, enabling Low Power mode will slow the running speed of CPU, and disable Mail Fetch, Background App Refresh, motion effects, and animated wallpapers.
You May Like: How to Make More Room on iPhone >
Besides the Low Power Mode on iOS 9, you can clean out your iPhone/iPod/iPad to optimize the running speed of your iOS devices to save the extra power of the battery from time to time with the help of PhoneClean.
