How to Enable Voice ID for Hey Siri in iOS 9
"Hey Siri" allows you to activate your iPhone with your voice. This post shows you how to enable voice ID for "Hey Siri" on your iPhone running iOS 9 with detailed steps.
Oct. 27, 2015
AnyTrans – Best iOS Content Manager for iOS 9
AnyTrans – No. 1 iOS 9 Data Manager
Have a try on AnyTrans so you can easily transfer & manage iOS data on your iPhone iPad after reading this post on how to enable voice ID for "Hey Siri" on iPhone.
With its intelligent features, the Apple Siri can be called a mind reader. iOS 9 has bought a set of new improvements to Siri, and we will discuss how a user enables voice ID for Hey Siri on iPhone in this quick guide.
"Hey Siri" can be easily enabled when you activate your new iPhone 6s or iPhone 6s Plus, because it is one of the setting-up procedure of your new phone. In addition, you can also set up your voice ID for "Hey Siri" on iPhone 6/6 Plus after you update your device to iOS 9.
Also Read: Common iOS 9/iOS 9.1 Problems and Solutions for You >
How to Set Up Voice ID for Hey Siri on iPhone
Step 1. Launch Settings app on your iPhone.
Step 2. Go to General, and tap on Siri.
Step 3. If Allow "Hey Siri" is off, turn it on. If it is on, turn it off and then toggle it on again.
Step 4. Tap Set Up Now.
Step 5. Say Hey Siri when it prompted. Say Hey Siri again when it asked. Say Hey Siri again.
Step 6. Say Hey Siri, how's the weather? when prompted.
Step 7. Say Hey Siri, it's me.
Step 8. Tap Done.
Enable Voice ID for "Hey Siri" in iOS 9
That's all! Now Hey Siri is smart enough to identify your voice, and when you're plugged in, "Hey Siri" will activate voice control on your iOS device only if it sounds like your voice.
You May Like: How to Transfer Data to New iPhone 6s/6s Plus >
To better manage your iOS content on iPhone, iPad, it is highly recommended to get a powerful iTunes alternative like AnyTrans on your computer. It is capable of transferring, backing up and managing your iOS data in a smart way.
If you haven’t updated to iOS 9, you will need to check this Complete iOS 9 Upgrading Guide, here you will know the preparations for iOS 9 update, the tips to free up space for iOS 9, and the ways to speed up iOS 9 devices etc.
