How to Fix Android Home Screen Keeps Crashing
Android home screen crashing can be very frustrating as it put everything to a standstill for some time. So, here, we will give some effective tips to solve Android home screen keeps crashing issue.
By | Last Updated: May. 05, 2019
Home > Android Transfer > Android Data Transfer> How to Fix Android Home Screen Keeps Crashing
Android is the world biggest smartphone platform with that has captured over 70-80% market. Android’s user-friendliness and lots of customizable features are the main reasons behind its popularity among users. But, like iOS, Android users also encounter some error while using their smartphones. Android Home screen keeps crashing is one of the issues that people encounter on their Android device, especially those with custom launchers like Samsung, Sony, LG etc. The customization made by the manufacturers makes the launcher heavy, which causes it to crash.
When your Android home screen crashes, everything from the home screen will disappear when leaving certain apps and the home screen will load again after few seconds. Though, it is also possible that Android home screen keeps stopping error may occur on the stock Android launchers as well, especially on a device with low RAM. So, in this post, we will tell you effective tips on how to fix Android home screen keeps crashing issue.
It is not that uncommon to encounter Android home Screen keep stopping on Android devices. Though it isn’t a serious problem, still it can be frustrating to wait for the home screen to appear when switching or leaving apps. Below we will give you all the solution to fix Android Home screen keeps stopping issue –
Tip 1: Clear RAM
Since the Android home screen keeps stopping issue is commonly encountered when you minimize apps. Though Android device has the ability to multitask, a lot of these files in the background can eat up a lot of RAM. The launcher may not get sufficient RAM and cause your Home screen to crash. So, to prevent Home screen keep crashing issue, you need to clear some RAM by closing some apps and avoid running several apps in the background. Moreover, you can clean some RAM by closing unnecessary apps.
How to Fix Android Home Screen Keeps Crashing - Clear RAM
How to Fix Android Home Screen Keeps Crashing – Clear RAM
Tip 2: Clear Launcher Cache and Data
Like every app, launcher app also saves some cache or app data on your device storage and this could slow it down. If you are using a different launcher than the default launcher, then the problem could be even more severe. So, you can try clearing the cache and data for the launcher to solve the Android home screen keeps crashing issue. You can do this by going to Settings > Application Manager > Select the launcher > Clear Data and Clear Cache.
How to Fix Android Home Screen Keeps Crashing - Clear launcher cache and data
How to Fix Android Home Screen Keeps Crashing – Clear launcher cache and data
Tip 3: Try a DifferentLauncher
If you have an Android device from other manufacturers that add their launcher to their devices as the default launcher, then you would most likely encounter the Android Home screen keeps crashing problem. Though you can’t uninstall the default launcher, you can at least install a new launcher from Google Play Store and this should solve your problem.
Tip 4: Factory Data Reset
If nothing seems to work for solving Android home screen keeps crashing issue, then you can try factory resetting the device to solve the issue. This will delete all apps, apps data and settings. Though, it won’t delete the media files like images, or others if you don’t choose it.
How to Fix Android Home Screen Keeps Crashing - Factory Data Reset
How to Fix Android Home Screen Keeps Crashing – Factory Data Reset
Bonus Tip: How to Backup Android Data to Computer Quickly
During the process of fix the problem Android home screen keeps crashing, there are chances that your Android data may get lost due to system crashing, Internet disconnection of mistaken deletion. To keep your Android data safe, AnyTrans for Android can be a great helper to backup all your Android data to computer within steps. You can transfer all your data to computer at once as well as transfer them in a selective way. Check the detailed steps below:
Before start, you can free download AnyTrans for Android to your computer and then follow the steps below:
Step 1. Install it on your PC/Mac > Connect your Android phone. Scroll down to go to the category page and click on Content to PC/Mac.
How to Backup Android Data to Computer – Step 1
Step 2. Check the categories you want to backup to computer > Select the export path > Click on Right Arrow to start.
How to Backup Android Data to Computer – Step 2
So, if you are encountering this error as well, then the tips given here can help you solve the Android home screen keeps stopping the problem. And  AnyTrans for Android will be a good android data manager if you want to transfer data from Android to computer or from iPhone to Android. Just get it now and have a free trial now >
Joy Taylor
Member of iMobie team as well as an Apple fan, love to help more users solve various types of iPhone related issues.
AnyTrans ® for Android
The best tool to transfer, back up and manage your Android data: to computer, to another Android device, add from computer.
  • * 100% Clean & Safe
