How to Fix Audible Error 3004 on iPhone 6s/7/8/X/XS(Max)/XR
Got an audible error 3004 iPhone? Looking for the methods to fix it? Then, you have come to the right page. Here, we have covered several methods that you can try to come out of this problem.
By iMobie | Posted on: Nov. 07, 2018, Last Updated: Nov. 07, 2018
Home > AnyTrans > iPhone Transfer > How to Fix Audible Error 3004 on iPhone
It is a very rare case when you encountered with error 3304. Users face this error while updating or restoring their iPhone with iTunes. Why this error occurs? There is no clear reason as it is not a common issue, but still, users have reported continuously for its method to fix it. If you are one of those users who is going through this error then refer to this guide as here we provide methods to fix audible error 3004 on iPhone.
How to Fix Audible Error 3004 on iPhone? Error 3004 seems to be impossible to resolve, but there are methods that you can try. So, try below-mentioned methods one by one.
Method 1: Check Internet Connection:
First of all, check your Wi-Fi internet connectivity and make sure that you have a reliable and stable internet connection. Try to turn off and on your internet several times. If you are using a modem then unplug and plug it again. Before proceeding with below methods, ensure you have connected your computer and iPhone to a good internet connection.
Method 2: Restart iPhone and System:
If there is no problem in the connectivity then restart your device and computer as well. Restating can fix various minor software issues. Therefore, if you are facing the problem due to software issue then restarting will fix your issue and you can then update or restore your iPhone with iTunes without any trouble.
Restart iPhone 8 or later:
Hold down both power and volume down or up button together until power slider does not appear on your iPhone screen. Drag the slider and then, press and hold the power button until the Apple logo does not appear.
Restart iPhone 7 or earlier:
Hold down the side button until the power slider does not appear on your iPhone screen. Drag the slider and hold the power button until you don’t see the Apple logo.
Method 3: Check iTunes version:
To update or restore iPhone with iTunes, you need to ensure that you have latest iTunes version. Otherwise, you can face iTunes error like now you are facing audible error 3004 iPhone.
On Mac:
Step 1: Open the Menu and then, go to “System Preferences”.
Step 2: Thereafter, tap on the “Software Update” and it will automatically update the iTunes version.
How to Fix: Audible Error 3004 on iPhone via Check iTunes version (On Mac)
On Windows:
Step 1: Run the iTunes on your computer and then, click on the “Help” option from its menu bar.
Step 2: Then, choose “Check for Updates”. If an update is available, then download and install it.
Note: If you have downloaded iTunes from Microsoft Store then it will automatically update iTunes version when it is available.
How to Fix: Audible Error 3004 on iPhone via Check iTunes version (On Windows)
Method 4: Disable the Antivirus Firewall:
If you have installed the antivirus software on your computer then it can be the reason why you are going through error. So, you can fix it by turning off the Antivirus and again try to restore or update iPhone via iTunes to check if the error is gone or not.
Method 5: Verify Date and Time of System:
Sometimes, the incorrect time zone can also put you in this situation. So, you need to make sure that you have set correct time and date on your computer and iPhone.
That’s all to fix audible error 3004. We have complied probable methods that can fix this error. Hopefully, you will be able to come out of the issue with the help of above-mentioned methods. Must share the guide with your friends also who encountered with the same error and this can be very helpful for them.
