How to Fix iPhone iPad Brightness Not Working on iOS 10
Are you confused with the iPhone iPad brightness not working in iOS 10, then you can read this guide to get the solution to fix this brightness issue.
Aug. 30, 2017
AnyTrans – Manage iPhone/iPad/iPod Content with Ease
AnyTrans – Best iPhone File Manager
This easy-to-use iTunes alternative can help you transfer iPhone/iPad/iPod data without limit. Remember to give it a try after you have fixed iOS 10 brightness issues.
For now, iOS 11 is coming to us, if you have also encounter some iPhone iPad iPod problems and issues during or after upgrading to iOS 11, you can refer to this guide for solutions: 30 Most Common iOS 11 Problems and Solutions >
It has been a few weeks since the public release of iOS 10. Apple called it "the biggest release of iOS ever", and indeed it has added many new and cool features to this brand new operating system, like the bubble effects of iMessages, the bedtime wake up alarm etc.
However, many users also meet some problems after updating iPhone/iPad to iOS 10. The brightness problem is one of them. Some users say that there seems to be a brightness not working, or decrease in iOS 10 on their iPhone, iPad or iPod. Here in this guide we will tell you how to fix the iOS 10 brightness issues. Let's get it on.
Also Read: Top 16 Tips to Save Battery on iPhone/iPad >
There is a setting called Reduce White Point on your device. Most users will not find it until others mention it. When you turn this feature on, it will reduce the intensity of bright colors on your iPhone/iPad, and then you will have a dim screen.
You may say that you haven't turned it on at all. Yes, it might be true. It can be Apple switches it on when you update to iOS 10 and then you may find the brightness decrease. Now follow the steps below to see how to fix this iOS 10 brightness problem.
Step 1. Go to Settings app > Tap on General.
Step 2. Tap on Accessibility > Choose Display Accommodations.
Step 3. Turn Reduce White Point off. Or you can also adjust the intensity of bright colors by dragging the button.
Hope this guide can help you fix iOS 10 brightness issues successfully. And do not forget to have a free try on AnyTrans, it will not let you down.
