How to Fix iOS 12 Screenshot not Working on iPhone/iPad
Do you want to capture a screenshot but your iPhone/iPad running iOS 12 refuses to do that? No worries, there are multiple methods to fix the screenshot issue on your iOS 12 device and the following guide shows those methods for you to easily get screenshot not working on iPhone iPad.
By iMobie | Posted on: Sep. 11, 2018, Last Updated: Sep. 11, 2018
Home > AnyTrans > AnyTrans for iOS > How to Fix iOS 12 Screenshot not Working on iPhone/iPad
iOS devices are equipped with the ability to help you capture screenshots of your device. All you need to do is press the combination of buttons and a screenshot will be taken and saved on your device. However, those of you running a certain version of iOS complain that iOS 12 screenshot feature is not working on your devices.
There could be various reasons as to why you are facing the screenshot feature not working issue on your iOS 12 device. Perhaps you are not pressing the key combination as it is supposed and thus you can’t take a screenshot. Or maybe there is an issue on your device that needs some fixing. Regardless, the following guide will help you fix the screenshot issue on your iOS 12 running iPhone or iPad.
Try all of the methods given below until you find the one that works for you. There will definitely be at least one method that will work for you and help you get rid of the screenshot issue on your device.
1. Press the Home and Power Buttons at the Same Time
It often happens that you press one button a few seconds prior to pressing the other button and that fails the screenshot taking procedure. In that case, your iPhone or iPad will perform the action of the button that you have pressed rather than doing what the combination of the buttons should do.
Therefore, it’s suggested that you press both Power and Home buttons at the same time. You can press the Power button a second before pressing the Home button and that will work.
2. Use AssistiveTouch to Take Screenshots on iPhone/iPad
AssistiveTouch is a feature on your iOS device that enables you to capture screenshots without needing to press any buttons. It adds an icon to your screen that you can tap on to take screenshot and do a few other tasks.
Step 1: Enable the AssistiveTouch feature on your iOS device by heading to Settings > General > Accessibility > AssistiveTouch and turning the toggle to the On position.
Fix iOS 12 Screenshot not Working with AssistiveTouch - Step 1
Fix iOS 12 Screenshot not Working with AssistiveTouch – Step 1
Step 2: A new white icon will appear on your device’s screen. Tap on the icon and then select Device followed by More. Tap on the option that says Screenshot and a screenshot of your screen will be captured and saved on your device.
Fix iOS 12 Screenshot not Working with AssistiveTouch - Step 2
Fix iOS 12 Screenshot not Working with AssistiveTouch – Step 2
That was how you could take a screenshot without needing to press any buttons.
3. Forcibly Reboot Your iPhone/iPad
It could be that something is stuck in the system of your device and a force reboot will likel resolve the issue for you. Force rebooting an iOS device doesn’t do any harm nor does it delete any content from your device. Here’s how to do it.
While your device is powered on, press and hold the Home and Power buttons simultaneously for about ten seconds. Your device will reboot. When it boots-up, try taking a screenshot and see if it works.
4. Update Your iOS Version on Your iPhone/iPad
Apple may have released a minor fix as an iOS update to help you resolve the screenshot issue on your device and you can easily download and install it as shown below.
On your iPhone or iPad, open the Settings app and tap on General followed by Software Update. All the available iOS updates will be shown here. Tap on the Download and Install button to download and install the selected update on your device.
Fix iOS 12 Screenshot not Working with iOS Updating
5. Charge Your iPhone/iPad Before Taking Screenshots
iOS may prevent you from doing certain tasks including taking screenshots when your battery level is low. Therefore, to get around the issue, charge your iPhone or iPad and ensure they have at least 60% battery level before you try to take a screenshot.
If it was the battery level causing the issue, charging your device will fix the issue for you.
Do these tips work for you? If they do, please share this post on twitter to help more people fix this issue of iOS 12 screenshot not working on iPhone iPad.
If the screenshot feature has suddenly stopped working on your iPhone or iPad running iOS 12, the above guide should help you fix the issue using various ways. It isn’t a major issue so you should be able to fix it by yourself without much hassle.
