How to Fix iPhone Keeps Asking for iCloud Password Issue
Many iOS 9/9.1/9.2 users complain that their iPhone keeps asking for iCloud password every time they turn it on. This guide will show you some possible fixes to this problem.
Dec. 25, 2015
AnyTrans – Manages Data on Your iOS 9 Devices
AnyTrans – Full-way iOS 9 Data Manager
Have a try on this amazing iOS file manager that helps backup, transfer and organize iPhone data after reading this guide on how to fix iCloud keeps asking for password issue in iOS 9.
"Does anyone else's iPhone ask for their iCloud password every single time they turn on their iPhone? This started happening after I updated to iOS 9.1."
-- Andres Questioned in MacRumors
Many iPhone users are annoyed with constant iCloud sin in request, and the iPhone seems to keep asking for your iCloud password. This is an old bug that plague many people even after an iOS 9 update. More specifically, the request repeats even if you entered the password, and this happens usually after an iOS update, a reboot or device restore. It is extremely frustrating. Here are some potential fixes to solve the iCloud keeps asking for password issue on iPhone/iPad.
How to Fix iPhone Keeps Asking for iCloud Password Issue in iOS 9
Also Read: The Most Common iOS 9/9.1/9.2 Problems and Fixes >
Possible Solutions to Fix iPhone Keeps Asking for iCloud Password
1. Download the Latest iOS
Update your iPhone to the latest iOS to see if the new system fixes the problem or not. Go to Settings > General > Software Update. Or open iTunes > Plug in your iPhone > Click the Device button > Under Summary, click Check for Update.
You May Like: Should I Update My iPhone to iOS 9 >
2. Restart the iPhone:
The simplest solution to solve this problem is to reboot your iPhone. The easy restart procedure works for most people. Just hold down the Sleep/Wake button for five seconds until the Slide to Turn Off appears. After turn off your iPhone, wait for few seconds, and press the Sleep/Wake button to turn on your iPhone again.
3. Re-login iCloud Account:
Tap Settings > iCloud > Sign Out > Tap Sign Out in the Popup menu > Tap Delete from My iPhone > Enter your password > Click Turn Off.
Once you are signed out, reboot your iPhone, and then to Settings > iCloud > Type in your Apple ID and password to re-login iCloud account.
Can’t Miss: How to View and Export Messages from iCloud >
4. Reset Settings:
Reset settings on your iPhone will not erase any data. Settings > General > Reset > Reset All Settings > Type in your password > Confirm Reset All Settings. Your iPhone will restart.
5. Check App Store/iTunes Store
If there is a failed download in App Store or iTunes Store, your iPhone may ask for your iCloud password for downloading the item. Firstly, go to the App Store to check your Purchased Apps history and see if there is an app that doesn’t been downloaded properly. Then go to Settings and choose iTunes & App Store and try signing out your Apple ID and then log in again.
As an iPhone, iPad or iPod user, you can get an iTunes alternative to backup, transfer, and manage your iOS data. AnyTrans is such a tool that helps you transfer photos, videos, music, contacts, notes, messages, ringtones, and more among iDevice, computer, and iTunes. Download It to Have A Try >
Best iOS Manage Tool – AnyTrans
If you have any better solutions to solve the iPhone keeps asking for iCloud password issue, please let up know in the comment sections. We hope the above fixes work for you, if not, our apologies.
