How to Fix iPhone 5/6/6s/7/8/X Ear Speaker Not Working
Has the ear speaker stopped working on your iPhone 5/6/6s/7/8/X/XS (Max)/XR? No worries, there are some really simple ways to get around the issue and fix the ear speakers so they start working again on your device. Read on to learn how to do it.
By iMobie | Posted on: Sep. 18, 2018, Last Updated: Sep. 18, 2018
Home > AnyTrans for iOS > iPhone Tips > How to Fix iPhone 5/6/6s/7/8/X Ear Speaker Not Working
All of a sudden you realize that the ear speakers on your iPhone X/XS/XR, iPhone 8, or any other model for that matter have stopped working. Well, this has happened to a lot of users as your iPhone sometimes forgets what mode to use to deliver audio and thus ends-up sending nothing to the ear speaker and so you don’t hear anything.
To fix the iPhone 6 ear speaker not working issue, you can follow some of the tips we have mentioned below. In addition to iPhone 6, these tips will work for other models of the iPhone as well so feel free to apply them on any of your iPhone models. They will not do any harm to your device so stay worry-free.
Fix iPhone 5/6/6s/7/8/X/XS (Max)/XR Ear Speaker Not Working
Method 1. Fix iPhone Ear Speaker Not Working Issue – Resetting iPhone
One of the simplest ways to fix the issue is to reset your iPhone. This has worked for many users to fix iPhone 6s and other ear speakers not working issue so you should check this out as well.
What you need to do in this method is simply press two buttons and it will do its magic. Press and hold down the Home and Wake buttons simultaneously on your iPhone for a few seconds. Wait for the Apple logo to appear and then let go of the buttons.
Your iPhone should reboot and you will have fixed your ear speaker not working issue.
Method 2. Fix iPhone Ear Speaker Not Working Issue – Restoring the iPhone
Fix iPhone 6 Ear Speaker Not Working Issue – Restoring the iPhone
Another possible fix that you can apply is to restore your iPhone. To do it, all that you are going to need is a computer and the iTunes app installed on it. The app is free so go ahead and grab it if you don’t already have it.
Connect your problematic iPhone to your computer using a suitable cable and launch the iTunes app. Click on your device in the app and then head to the tab that reads Summary. You will find an option that says Restore iPhone. Click on it to begin restoring your device.
When your iPhone has been fully restored, you will find the ear speaker not working issue is gone. It’s no longer there and you have a fully working ear speaker on your iPhone.
Method 3. Fix iPhone Ear Speaker Not Working Issue – Plugging-in Earphones
Sometimes your iPhone thinks it is in the earphone mode and thus does not send any audio signals to the ear speaker. If that’s the situation with your iPhone, you might want to remind your device to get back to the normal mode.
An easy way to bring your iPhone back to normal mode is to plug-in and out your earphones a few times. You will then find that you are able to hear audio using the ear speakers and the trick worked for you.
Method 4. Fix iPhone Ear Speaker Not Working Issue – Remove Dirt from the Ear Speaker
Over the time the ear speaker port may have collected dust and other bad particles and those could be causing the issue. The best way to get rid of the issue if this is the reason is to clean up the port. Use a clean cloth to gently wipe the port. You can also use alcohol if available. Cleaning the port should help resolve the issue and you should be able to get your ear speaker to work again.
That’s all about how to fix iPhone 6 ear speaker not working problem. If the ear speakers have suddenly stopped working on your iPhone, do not panic as there are multiple ways to get around the issue on your device. Follow our guide above and you should be able to get rid of the problem from any of your iPhone models.
