How to Fix No Text Sound on iPhone 7/7 Plus
This article is going to tell you reasons of iPhone 7/7 plus no text sound issue, and collects 5 practical solutions to help you fix it.
Joy Taylor Last Updated: Apr. 14, 2020
Currently, the iPhone 7 is one of the best smartphone models that Apple has released. And although it comes with superior hardware specs and many amazing new features, it also with some small imperfect issues. One of the outstanding problems is that there always no text sound on iPhone 7 and iPhone 7 plus, which is denounced by many users. In this troubleshooting guide, we will tackle the iPhone 7 no text sound issue that you may experiencing right now.
If you own an iPhone 7 or iPhone 7 plus and facing the issue of iPhone tex sound not working, read on, try following methods to see if they can resolve your problem.
Mute Switch on iPhone
1. Mute Switch
On the left side of your iPhone 7, above the volume button, there is a Ring/Silent switch, make sure that you haven’t switched it on the mute mode.
2. Do Not Disturb
Make sure that Do Not Disturb is off, you can check it by going to Settings > Do Not Disturb. If you forget to turn it off, now, turn it off. Moreover, ensure that Do Not Disturb is not turned on for any particular contacts. To check this, launch the Messages app where you can see your messages. If any message have any moon sign that is mean you enabled Do Not Disturb for that number.
Do Not Disturb
Do Not Disturb
3. Bluetooth Off
If you enabled Bluetooth on your iPhone, then go to Settings and click on Bluetooth, turn it off. If you have never used the Bluetooth speaker or headset, you can skip this solution.
Bluetooth Off
Bluetooth Off
4. Restart Your iPhone
Try to restart your iPhone, to do this, you can press and hold the power button until “slide to power off” appears on the screen, then slide to power off. Turn it back on to check the text sound.
5. Reset Your iPhone
You can reset your iPhone by going to Settings> General> Reset> Reset all settings. Make sure to backup your iPhone to the cloud / iTunes in advance as this will remove your media, music, apps and more data from your iPhone.
Bonius Tip: How to Make Any Song as Ringtone on iPhone
After talking about how to fix there is no text sound on iPhone 7, in this part, we’re going to recommend you an amazing iOS data transfer tool – AnyTrans, which can help you transfer kinds of iOS content from computer to iPhone without wiping any data. And besides this, it can help you set any song as ringtone for your iPhone. Following are the detailed steps:
Step 1. Download and install AnyTrans on your Mac or PC computer, launch it and connet your iPhone 7 with USB.
Step 2. Choose Device Manager and click Music.
How to Make Any Song as Ringtone on iPhone - Step 2
How to Make Any Song as Ringtone on iPhone – Step 2
Step 3. Select Ringtones. You can see there are only two ringtone on my iPhone. Then click the “+” button and browse music, here we can select songs we like, then click on Open to transfer them from computer to iPhone to as ringtone.
How to Make Any Song as Ringtone on iPhone - Step 3
How to Make Any Song as Ringtone on iPhone – Step 3
After transferring successfully, you can open your iPhone to check. Now, you can see the transferred songs already became ringtones on my iPhone.
Check Ringtones on iPhone
Don’t Miss: How to Transfer Playlist from iTunes to iPhone >
Try out methods listed above to fix your iPhone 7 no text sound issue, hope one of them can work for you. By the way, if you want to transfer iOS content without data losing, or make your loved songs as your exclusive ringtones, you can have a try on AnyTrans.
Joy Taylor
