5 Methods on How to Fix iPhone Headphone Jack Not Working
You must be really worried if you can’t listen to the music with your headphones. At this time, there is probably something wrong with your headphones or headphone jack. So how to work out it? This post is going to provide with 5 methods to fix iPhone headphones jack not working properly.
By iMobie | Posted on: Sep. 18, 2018, Last Updated: Sep. 18, 2018
Home > AnyTrans > AnyTrans for iOS > 5 Methods on How to Fix iPhone Headphone Jack Not Working
AnyTrans – iOS Data Transfer
Want to transfer music, photos, contacts, messages or any other data and files as you like? Want to experience full-way transfer across iPhone, iPad, iPod, iCloud, iTunes and computer? Download the latest version of AnyTrans for iOS.
If you are an iPhone user then there must be times that you faced the problem when your iPhone headphone jack is not working properly. The problem is quite common and almost every 7 out of 10 iPhone users have faced this kind of situation which can be fixed with simple methods. As the music is the best escape we have from the real world, the immediate fix of iPhone headphone jack is very important. So, we are providing you some best and effective fixes that you can try to fix the headphone jack issue.
All the methods that you can try to fix iPhone 5/6/7 headphone jack not working are given in details in the following section.
Method 1. Use New Headphones
The first method that would fix the iPhone headphone jack not working problem is the replacement for your headphones. Instead of a faulty jack of the iPhone, it can be the headphones that might be faulty and resulting in the problem. So, buy new and original iPhone headphones and insert them to check if the problem still persists. Try out calling someone, playing music and using Siri, if the new headphones have a mic. If the new headphones are working, then it was not the jack problem which was causing the trouble.
 Method 2. Clean up the Headphone Jack
The iPhone is also a piece of technology that is vulnerable to dust particles. Sometimes debris and dust particles gather inside the jack that could be the cause of the problem. Clean up the headphone jack either by using a cotton swab, ear bud dipped in alcohol, or by using a vacuum nozzle. This will remove the dirt from the jack and you will have a solution for your “iPhone 5 headphone jack not working” problem along with other models.
Method 3. Restart the iPhone
The iPhone 8 and iPhone X has a different method to restart the iPhone. But the previous models like iPhone 5, iPhone 6, and iPhone 7 share the same method to restart the iPhone.
For iPhone 8 and X, press and hold the Power button and the slider will appear on the screen. Drag the slider from left to right and your iPhone will switch off. Do the same to turn the iPhone back on and see if the problem is still there.
Fix iPhone Headphone Jack Not Working - Restart the iPhone
Fix iPhone Headphone Jack Not Working – Restart the iPhone
For iPhone 7, iPhone 6, 6S and iPhone 5, press the Power button present on the top or side of the iPhone depending upon your model and hold it until you see the slider. Now drag the slider to right and turn your iPhone off. Now turn it back on and check if the problem still persists.
The restart will clear up the iPhone’s active memory and preferences that could be the source of the problem. It will most probably fix the “iPhone headphone jack not working properly” problem and your jack will work accurately.
Method 4. Check the Airplay Output
The reason that your iPhone 6s headphone jack is not working might be because the iPhone is playing the audio to some other output. Usually, the iPhone detects that the headphones are plugged in automatically. But in some cases, this does not happen and people think that it is the jack that’s not working properly. The audio might be sent to the AirPlay or AirPods.
To check if that’s the case, follow the steps:
Step 1Open the Control Center and long press the Music playback controls.
Step 2When the playback controls open up, tap on the AirPlay button and it will display the available Output sources.
Step 3Tap on the Headphones and dismiss the Control Center.
Fix iPhone Headphone Jack Not Working - Check the Airplay Output
Fix iPhone Headphone Jack Not Working – Check the Airplay Output
As the audio is now being sent to the headphones, you will be able to play the music. If not, then try out the next method.
Method 5. Check the Bluetooth Output
The same situation with AirPlay can be repeated with the Bluetooth. If your iPhone is connected to some external device like a speaker, then you can do a simple test to check it:
Step 1Open the Control Center and tap on the Bluetooth icon so that the icon is not lit up. This is done to disconnect the iPhone from the Bluetooth device it is connected to.
Step 2Try inserting your headphones now and it will be able to play the audio.
How to Fix iPhone Headphone Jack Not Working - Check the Bluetooth Output
How to Fix iPhone Headphone Jack Not Working – Check the Bluetooth Output
We provided almost all the solutions possible for headphone jack not working iPhone 6/6s/7 problem. If none of the above solutions worked for you then it really means that your headphone jack is seriously broken and you need to get it fixed. Make sure that you visit the Apple store instead of relying on some other methods.
Christian Chus
AnyTrans ® for iOS
  • * 100% Clean & Safe
11,452,517
Users Served
