iTunes could not backup the iPhone and you are looking for ways to fix it? If yes, keep reading on this quick guide to know how to fix the issue.
Question: My iTunes freezes constantly and my husband’s iPhone’s and mine have stopped backing up in iTunes. I get an error when it does go through the process that says, “iTunes could not back up the iPhone “. How Can I fix this?
— A User from Microsoft Community
Solution 1. Restart your computer and your iPhone.
Solution 2. Download and install the latest version of iTunes on your computer.
Solution 3. Make sure your iOS device trusts your computer: unlock the device and tap Trust.
Solution 4. Make sure that you are using the Apple-supplied USB cable.
Solution 5. Check security setting: update, configure, disable, or uninstall your security software.
Solution 6. Delete old iTunes backups on computer: Open iTunes > Go to iTunes menu bar > Preferences > Devices > Delete Backup. Check out how to locate iTunes backup.
Solution 7. Locate the backup in Solution 5 and then rename the backup name.
Solution 8. If none of the above solutions works, and it is pressing for you to back up your iPhone to iTunes, you can have a try on AnyTrans. It is a flexible iTunes alternative to backup, transfer, and manage iOS files.
Solution 9. Try an iPhone issues troubleshooter – AnyFix.
AnyFix is one of the best iPhone issues troubleshooters. It helps iPhone users to get out of problems with a few clicks. Besides the iPhone issues, AnyFix provides professional solutions to fix iTunes problems with ease. Therefore, you can give AnyFix a try to eliminate the problem in minutes.
Tap on System Repair
Step 1. Download AnyTrans, and install it on your PC or Mac > Connect your iPhone to the computer via USB cable > Choose Backup Manager.
How to Make an iTunes Backup on iPhone in 1 Click – Step 1
Step 2. Click on the Full Backup button.
How to Make an iTunes Backup on iPhone in 1 Click – Step 2
Step 3. After clicking the Next button, AnyTrans will start to back up all your files on the iPhone.
How to Make an iTunes Backup on iPhone in 1 Click – Step 3
Step 4. Open the iTunes app on your computer and you will see the backup you just made with AnyTrans is listed in your iTunes.
Check the Backup in iTunes
For more iTunes backup or restore problems and solutions, please check out How to Fix: iPhone Backup Corrupt/Not Compatible or iTunes Could Not Restore iPhone Because of Not Enough Space. For a better managing and backing-up experience on your iPhone, AnyTran is a good choice for you. Have a try on its free trial now >
