How to Fix iTunes Error 0xe80000
If you are getting the message of “iTunes could not connect to this iPhone. An Unknown error occurred 0xe80000”, this post is exactly what you need. In this article, we will offer you some tips to fix iTunes error 0xe80000. Keep reading and get more.
By iMobie | Posted on: May. 22, 2018, Last Updated: Jun. 13, 2019
iTunes is the official device management application of Apple to manage and organize iOS device. It lets users update, backup and restore their iOS device as well as manage their music and video library. Though most of the time it seamlessly lets users manage their iPhone, many users are complaining that message of “iTunes could not connect to this iPhone pops out whenever trying to connect their iPhone to a windows computer.
Currently, the exact reasons behind iTunes error 0xe80000 are still unknown. However, in this post, we have summarized a few methods which are proved to be effective to solve iTunes error 0xe80000. If you are stuck in iTunes Error 0xe80000, do give those methods a try and see if they work.
Tip 1: Reboot iPhone and iTunes
The iTunes error message – “iTunes could not connect to this iPhone. An unknown error occurred 0xe80000” can occur when the iTunes could not identify your iPhone due to some reason. So, you can try rebooting your device so that the iTunes sync can work seamlessly. You can also close and restart iTunes so that you can sync your iPhone with iTunes without any problems.
Fix iTunes Error 0xe80000 - Reboot iPhone and iTunes
Fix iTunes Error 0xe80000 – Reboot iPhone and iTunes
Tip 2: Updating iTunes
The iTunes Error 0xe80000 can also occur when you try to sync your iPhone with iTunes if the iTunes is outdated. iTunes must always be updated so that it can work flawlessly. So, you should update the iTunes if you are encountering iTunes Error 0xe80000.
To update iTunes, open iTunes on your computer, click on “Help” at the menu bar and then select “Check for Updates”. iTunes should connect to the Apple servers and download and install the update if available.
Fix iTunes Error 0xe80000 - Update iTunes
Fix iTunes Error 0xe80000 – Update iTunes
Tip 3: Close AppleMobileDeviceService
When you install iTunes on your computer, many services will be installed along with it. One such service is AppleMobileDeviceService that continuously runs in the background when you use iTunes. But it can also conflict with iTunes and other services on the computer and show the iTunes Error 0xe80000. That’s why closing AppleMobileDeviceService works to fix iTunes error 0xe80000.
To close AppleMobileDeviceService, you should press Ctrl + Alt + Delete to bring Task Manager first, then disable AppleMobileDeviceService.
Fix iTunes Error 0xe80000 - Close AppleMobileDeviceService
Fix iTunes Error 0xe80000 – Close AppleMobileDeviceService
Tip 4: Enter the device into recovery mode
If you are still encountering the iTunes Error 0xe80000, then put your iPhone into recovery mode and this should fix the error. This is especially useful when you are encountering this error while updating or restoring your iPhone. To put your device in recovery mode, Press and hold the Sleep/Wake and Home button for a few seconds and the iPhone should restart. Now, release the Sleep/Wake button, while keeping the Home button pressed until you see the iTunes icon displayed on the screen. Now, you can connect your iPhone to the iTunes and proceed with the update or restore.
Fix iTunes Error 0xe80000 - Put the Device into Recovery Mode
Fix iTunes Error 0xe80000 – Put the Device into Recovery Mode
Bonus Tip: How to Manage iPhone Data with an iTunes Alternative
The methods to fix iTunes error 0xe80000 are not actually hard. After successfully fixing iTunes error 0xe80000, you can backup iPhone data to computer or sync data from computer to iPhone. However, iTunes is by no means the best way to manage iPhone data.
Above all, besides iTunes error 0xe80000, other tedious iTunes errors can also occur while using iTunes. Moreover, you can only create a whole backup of your iPhone with iTunes and selectively backup data is not an option. What’s more, the data in iTunes backup are not viewable. Finally, data loss might occur while syncing data from computer to iPhone.
For all mentioned above, you will need to update the way to manage iPhone data. Here we highly recommend AnyTrans for iOS.
AnyTrans for iOS is developed by an Apple certificated developer – iMobie Inc.. It is an all-in-one iOS data manager supports managing all types of data on iPhone. AnyTrans for iOS is said to be the best iTunes alternative because it can:
1. Help you selectively or backup all iPhone data to the computer as you wish. (28+ types of iPhone data are supported)
2. Lend you a helping hand to transfer data from computer to iPhone.
3. Seamlessly send data from iPhone to iPhone directly without backing up and restoring.
4. Help you view and extract data from iTunes backup then send them to your iDevice.
AnyTrans for iOS Overview
As you can see, AnyTrans for iOS is indeed an almighty tool to manage iPhone data. Why not free download it and let it help you manage iOS data with ease?
With the four methods, you may have successfully fixed iTunes error 0xe80000. Are those tips helpful? Share your ideas in the comment column. By the way, as you can see, AnyTrans for iOS is indeed an excellent iTunes alternative. Now, iMobie offers every user 7-day free trial. Why not download it and have a try?
AnyTrans ® for iOS
  • * 100% Clean & Safe
11,452,517
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
