Why iTunes Error 1601 Happens & How to Fix
If the iTunes app installed on your computer throws an error 1601, here’s how you can fix the error and get iTunes to work again on your machine. It’s pretty easy and you should be done in no time.
By iMobie | Posted on: Aug. 28, 2018, Last Updated: Aug. 29, 2018
Home > PhoneRescue > iOS Data Recovery > How to Fix iTunes Error 1601
So you’re trying to restore, update, or downgrade the operating system of your iOS device using iTunes on your computer but you suddenly get the iTunes error 1601. Well, you are not alone. The error does not occur too often but when it happens, it prevents you from performing any of the aforementioned tasks on your iOS device. You’ll keep seeing the error on your screen and it won’t let you move past that. Unless you find out the cause of the issue and resolve the issue, you will not be able to use iTunes to restore or update your iOS device.
You may be wondering why the iTunes error 1601 occurs and what you can do to prevent it from happening again on your computer. Well, there are a number of things involved that cause the error and below are some of those causes of the issue.
1. Using an unofficial USB cable
If you lost or broke your original Apple USB cable and you now use an unofficial one bought from a local store to connect your iOS device to your computer, you will likely face the issue. The reason being Apple doesn’t recommend using third-party cables for connecting Apple devices and so their apps are not suitable for these kinds of cables.
2. Broken USB port
If the USB port on your computer is broken and is not properly working, the app will likely throw the iTunes error 1601 on your screen.
3. Security software
If you have installed a security software that interferes with iTunes functionality, you will get the 1601 error in iTunes. This doesn’t happen with all the security software though.
Now that you have an idea what causes the error, you might want to learn how to fix iTunes error 1601 on your computer so you can successfully restore or upgrade your iOS device. There are multiple fixes that you can apply to fix the issue and the following are some of the best ones for you.
Solution 1. Get an official USB cable
If you have been using an unofficial USB cable to connect your iOS device to your computer, throw it away and buy a new official cable to use with your device. An official cable is certified by Apple and has everything in it to ensure data is transmitted between your device and your computer without any issue. You can head to the Apple website or an Apple store get an official cable.
Always Use the Official Apple USB Cable
Solution 2. Fix the USB port on your computer
If you face the issue even after changing to the official Apple USB cable, see if your USB port has gained dust or if it is not working for any other reason. One of the ways to check that is to plug in a USB flash drive and see if it appears on your computer. If it doesn’t, you have an issue with the port and it needs to be fixed. Get in touch with a computer technician and get the port fixed on your computer.
Get the USB Port Repaired on Your Computer
Solution 3. Disable the security software on your computer
You may have installed a software to protect your computer from various threats but it could be preventing iTunes from doing its functions. You are suggested to exit any of the security software you have installed on your computer while you use iTunes to restore and upgrade your iOS device.
If you use a Windows PC, quitting a security software is extremely easy. Simply find the software in your system tray and right-click on it and select Exit or Close option. The software will be closed on your PC.
Exit Security software on a PC
If you use a Mac, press the Command + Option + Esc key and choose the security software and click on Force Quit. The software will be closed on your Mac.
Exit Security software on a Mac
With the help of the above guide, you should be able to get rid of the iTunes error 1601 on your computer. As you may have noticed, it’s not much difficult to get around the issue on both Windows and Mac machines. We hope you have been able to fix the issue and can restore and upgrade your iOS devices using iTunes.
PhoneRescue ® for iOS
Recover your deleted iPhone iPad files with the highest success rate, no matter whether you have backups or not!
  • * 100% Clean & Safe
5,716,299
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
