Fix iTunes Error 1648 with 5 Methods
Usually, when you use iTunes on Mac or PC, the error code might occur. iTunes error 1648 is one of them. The article here is intended to teach you how to fix iTunes error 1648.
By iMobie | Posted on: Sep. 18, 2018, Last Updated: Sep. 18, 2018
When you use iTunes to update or restore your iOS devices on computer, you might see an error code or alert message. And one of the specific error numbers is error 1648. Many reasons are likely to cause the iTunes error 1648. If you have third-party security software on computer, it can prevent iTunes from connecting to Apple servers or to devices. Another possible reason to cause the error might be the hardware of your device.
Usually, you can fix the iTunes error 1648 with the steps in our guide. Head to have a check.
5 Solutions to Fix iTunes Error 1648
Here we introduce five basic methods to fix iTunes error 1648.
Solution 1: Check USB cable
Use the USB cable that came with your iPhone or iPad. If you don’t have it, try a different Apple USB cable.
Solution 2: Check USB port
Switch to a USB port on your computer, or switch to a USB port on a different computer to check whether the USB port works normally.
Solution 3: Check USB connections
Follow the steps below to check the connection between your device and computer. Please try them one by one.
1. Disconnect your iPhone or iPad with computer, then reconnect it.
2. Check if the cable connection at the device or computer got loose or unplugged.
3. Make sure your iPhone or iPad is connected directly to one of your computer’s USB ports, instead of a third-party battery pack or case, a USB hub, or to your keyboard.
Solution 4: Check Third-party Security Software
Check your hosts file to see if it is blocking your iTunes from communicating with the Apple’s servers.
For Mac users:
1. Go to Finder > Applications > Utilities, open Terminal, and type in “sudo nano /private/etc/hosts” and press Return.
2. Enter the password you use to log into computer and press Return.
3. Terminal should display the hosts file. Navigate using the arrow keys to find an entry containing “gs.apple.com”.
How to Fix iTunes Error 1648
4. Add the # symbol and a space (“# ”) to the beginning of the gs.apple.com entry.
5. Press Control-O to save the file.
6. Press Return when asked for the filename.
7. Press Control-X to exit the editor.
8. Restart your Mac and then try iTunes again.
For Windows users, please follow this site to reset the Hosts file back to the default.
Solution 5: Check Your Hardware
1. Update iTunes to the latest version.
2. Check for software updates
For Mac users: Open the App Store on your Mac OS X > Switch to Updates.
For Windows users: Go to Start button > All Programs > Windows Update.
That’s all for iTunes error 1648 solutions. Basically, your iTunes error 1648 can be fixed with the steps above. If unfortunately, the error remains, you’d better contact Apple Support for further help.
AnyTrans ® for iOS
  • * 100% Clean & Safe
11,452,517
Users Served
