Fix iTunes Error 1650 with 6 Methods
It is annoying that the update or restore cannot be accomplished smoothly due to an iTunes error code. Thankfully, your problem now has a solution. Here comes our article to help you fix iTunes error 1650.
By iMobie | Posted on: Sep. 25, 2018, Last Updated: Sep. 25, 2018
iTunes error usually occurs when you use iTunes to update or restore your device on computer. Different error code has its matching solutions. Heretofore, we have talked about the keys to resolve iTunes error 50, iTunes error 1649, iTunes error 3015. Plenty of users have been out of the woods. And to help more of you that see iTunes error 1650, we also have some possible solutions to share. Without further ado, let’s begin the steps to fix iTunes error 1650.
How to Fix iTunes Error 1650
Follow the steps one by one, you’ll find the solutions to fix your iTunes error 1650.
Tip 1. Check USB Cable
Check if you are using the USB cable that came with your device. If not, please at least make sure you are using an Apple-supplied USB cable.
Tip 2. Check USB Port
Try to switch to another USB port on your computer. Make sure your device isn’t connected to a third-party battery pack or case, a USB-hub, or to your keyboard.
Tip 3. Check USB Connection
Tip 4. Restart iPhone/iPad
For iPhone 8 or earlier, or iPad, press and hold the Top (or Side) button until the slider appears. For iPhone X/XS (Max)/XR, you need to press and hold the Side button and either volume button until the slider appears on screen.
Tip 5. Update iTunes to the Latest Version
The regular software update is always helpful for bugs’ fix or performance improvement.
For Mac users, go to App Store > Updates to check for iTunes update.
For Windows users, go to All Programs > Windows Update.
Tip 6. Check Third-party Security Software
Some third-party security software might prevent iTunes from connecting to Apple servers or to iOS devices, so follow the steps below to have a check.
For Mac users:
  1. Go to Finder > Applications > Utilities, open Terminal, and type in “sudo nano /private/etc/hosts” and press Return.
  2. Enter the password you use to log into computer and press Return.
  3. Terminal should display the hosts file. Navigate using the arrow keys to find an entry containing “gs.apple.com”.
  4. Add the # symbol and a space (“# ”) to the beginning of the gs.apple.com entry.
  1. Press Control-O to save the file.
  2. Press Return when asked for the filename.
  3. Press Control-X to exit the editor.
  4. Restart your Mac and then try iTunes again.
For Windows users, please follow this site to reset the Hosts file back to the default.
Hope the solutions for iTunes error 1650 above will do you a favor. If your problem remains, you’d better contact Apple Support for help. And any suggestions about resolving the error code are welcomed to share in the following comment section
AnyTrans ® for iOS
  • * 100% Clean & Safe
11,452,517
Users Served
