How to Fix Safari Running Slow on Mac
Safari running slow on Mac? Read this guide to learn several methods to fix this annoying problem.
Jun. 24, 2016
MacClean – Clear Safari Cache and History in an Easy Way
MacClean – Your Best Mac Cleaning Tool
This easy-to-use cleaning tool can help you remove unwanted junk files and caches from your Mac easily. You can download it to have a try after reading this guide on how to fix Safari running slow on Mac.
As the default browser of Mac, it is used daily by millions of people all over the world. But as time goes by, you may find the Safari running slower and slower. It’s time for you to take some action to make it run like beginning. Here in this guide we offer several methods to help you. Let’s get it on.
Don’t Miss: How to Delete History on Mac (Safari Chrome Firefox Opera) >
1. Clear Safari Cache, History and Website Data
Method 1.
Clear Cache: Open Safari > Preference… > Advanced > Check “Show Develop menu in menu bar” > Click on Develop menu > Click on Empty Caches.
Clear Safari Cache on Mac
Clear History and Website Data: Open Safari > Click on Safari in the menu > Click on Clear History and Website Data…
Method 2.
The above method cannot let you preview and select the caches and histories you want to delete. So we offer you another method that can make it.
MacClean, one professional Mac cleaning tool can help you find out and delete unwanted Safari cache and history on Mac in an smart way.
Step 1. Download MacClean and open it > Choose Internet Junk > Click on Scan button.
Clear Safari Cache and History with MacClean – Step 1
Step 2. Click on Review Details to choose the items you want to delete.
Clear Safari Cache and History with MacClean – Step 2
Step 3. Go back to the previous page > Click on Clean button
Clear Safari Cache and History with MacClean – Step 3
2. Disable Extensions
Some incompatible extensions can make your Safari running slow. You can turn them off to see if it solves the problem.
Open Safari > Preferences… > Extensions > Turn it off.
Also Read: 2 Ways to Remove Safari Plugins and Extensions on Mac >
3. Reset Safari
It can let you lose history, top sites, saved names and passwords etc. You can choose the items you want to reset. It is better to reset all the settings at a time.
Open Safari > Click on Safari in the menu > Click on Reset Safari… > Select the items you want to reset > Click on Reset button.
4. Log into Another Account
Just take 1 minute to create a new user account. Log into the new account and open Safari to see if it runs faster. And you can fix this problem with Disk Utility.
Open Disk Utility through Spotlight > Choose your hard drive > First Aid > Verify Disk.
You May Like: Using Disk Utility to verify or repair disks >
5. Upgrade to the Latest OS X
Upgrade to the latest OS X version can let you have the latest Safari. Go to App Store to download and install the latest version.
Don’t Miss: How to Clean Up MacBook Pro >
Hope this guide can help you speed up your Safari on Mac. You can share this guide with your friends if you like it. If you are interested in MacClean, just click here to have a free trial!
Top Posts on Cleanup and Speed Up Mac Computer
