How Does iPhone 8/X Wireless Charging Work
How does iPhone 8 (Plus)/iPhone X wireless charging work? Read on this post to obtain a better understanding of your iPhone 8 (Plus)/iPhone X wireless charging.
AnyTrans - Helps You Transfer Data from iPhone to iPhone with Ease
AnyTrans – #1 iOS Data Transfer
AnyTrans is a professional iOS data transfer that can help you easily transfer data from iDevices to iDevices/Mac/PC, and vice versa. Have a try after reading this guide on how does iPhone X/8 (Plus) wireless charging work.
Apple finally adds wireless charging technology to its new generation iPhone - iPhone X and iPhone 8 (Plus). iPhone 8 (Plus) /iPhone X Wireless charging is using the universal wireless charging standard, called "Qi", which is developed by the Wireless Power Consortium.
In recent days, lots of iPhone 8 (Plus) users reached out and asked about how does wireless charging actually work, and how safe is it? So, to help users have a better understanding of this convenient feature and check its safety, here in this guide, we will show you how does iPhone X/iPhone 8 (Plus) wireless charging work in detail.
How Does iPhone 8 (Plus)/iPhone X Wireless Charging Work
Wireless charging is based on the principle of magnetic resonance, or magnetic induction. In particular, it uses a loop of coiled wires around a bar magnet to create an electromagnetic filed around magnet, and then use it to transfer an electrical current between two objects.
In short, the wireless charger and device use magnetism to transmit power. So, with the same principle, iPhone X/iPhone 8 (Plus) Wireless charging uses two resonant inductive couplings to safely transfer the required energy from transmitting source to your device without the traditional USB cables.
How Does iPhone 8 (Plus)/iPhone X Wireless Charging Work – Screen Overview
Wireless charging provides a more convenient and safe way to charge smartphones. It is set to become more popular in our daily life. And Apple will announce its own wireless charging pad called AirPower, which will be available next year. The AirPower will support not only iPhone, but also Apple Watch and AirPods. You are also allowed to charge all these three devices at once. Let’s look forward to it.
How to Transfer Data from Old iPhone to iPhone X/ 8 (Plus) via 1 Click
As an Apple fan, you may have got an iPhone 8 (Plus) in your pocket to enjoy the hundreds of new features. After getting a new iPhone, how to move some of your important data from old iPhone to new iPhone would become one of the must to do things. But since transferring data via iTunes will erase the existing data on device and the process is complicated, plenty of users are looking for another reliable way to move files without iTunes.
If you are also one of these users, then stop here. In this guide, we will share you a labor-saving and reliable iTunes alternative – AnyTrans to help you finish the task in just 1 click. It supports transferring almost all your iOS files, including photos, contacts, messages, videos, ringtones, notes, etc. It will not erase any previous data on your device and the entire process just a few minutes is needed.
The primary one is that it enables you to preview and select the files, which means that you can choose the files you really want to move to your new iPhone 8 (Plus)/iPhone X. Here we will take photos for example. Let’s check its simple transferring steps now.
Step 1. Download and install AnyTrans on your Mac/PC > Launch it > Connect both your old iPhone and new iPhone 8 (Plus)/iPhone X to the computer with USB cables.
Step 2. Click Device tab > Select your old iPhone > Go to the category page.
How to Transfer Data from Old iPhone to iPhone 8 (Plus)/iPhone X – Step 2
Step 3. Click on Photos category > Choose the album contains the photos you want to transfer.
How to Transfer Data from Old iPhone to iPhone 8 (Plus)/iPhone X – Step 3
Step 4. Preview and select the photos you prefer > Click To Device button on the upper right corner to begin the process.
How to Transfer Data from Old iPhone to iPhone 8 (Plus)/iPhone X – Step 4
That’s all about how does iPhone X/iPhone 8 (Plus) wireless charging work. Have you got the main point? If you have any question, be free to leave your comment below or contact us via email, we will reply you soon. And lastly, AnyTrans is your most ideal choice to transfer data from one iPhone to another. Give it a try now, it will not let you down.
Join the Discussion on How Does iPhone 8 (Plus)/iPhone X Wireless Charging Work
