How to Add or Remove Widgets to Lock Screen on iOS 10
The Lock screen of iOS 10 is brand-new and this guide will show you how to add or remove widgets to/from lock screen on iOS 10.
Aug. 21, 2017
AnyTrans – iOS 10 File Manager
AnyTrans – Smart iOS 10 Content Manager
Have a try on AnyTrans to transfer, backup and manage your content on iOS 10 devices. Then read on this guide to learn how to add/remove widgets to iOS 10 lock screen.
Apple will release the iOS 11 this fall, should you update your iPhone? You can go to this Should I Update to iOS 11 guide to get the pros and cons of iOS 11 and make your final decision.
iOS 10 brings some notable changes. Since it was released many users have been upgrading their iPhone or iPad and find out that the lock screen is much different than before. Now you can add apps you use a lot to widgets in lock screen so that you can preview and access to them quickly.
The new lock screen lets you conveniently access the camera app and the widgets page via a simple swiping. The widgets can be customized, and you can also easily add or delete the widgets as you like.
You May Like: The Most Common iOS 10 Update Issues with Solutions >
1. On your iPhone or iPad’s lock screen, swipe to right to access the iOS 10 widgets page.
2. You will see some widgets here like Weather, Siri App Suggestions, or Calender etc. You can scroll down to see more widgets.
3. To add or delete a widget, scroll to the bottom of the screen and tap the Edit button.
4. You will need to enter your passcode before you can edit your widgets.
5. Now tap the red minus option to remove a widget and tap the green plus option to add a widget to lock screen.
How to Add/Remove Widgets from Lock Screen on iPhone
Note: If you want to manage your various types of data on iOS devices in a smart way, try AnyTrans. It helps backup your old iPhone before updating to iOS 10, including photos, messages, notes, contacts, music, videos, ringtones, books, etc. It does a great job on data management, and is much easier than iTunes. Download AnyTrans to Have a Free Trial >
Manage iOS Content on iOS 10 with AnyTrans
