How to Change Ringer Volume on iPhone 7/8/X/XS (Max)/XR
Can’t find a way to change ringer volume with volume button after updating iPhone to iOS 12/11? This post can render you solution on how to change ringer volume on iPhone. Don’t miss it!
Roger Smith Last Updated: Mar. 31, 2020
With the update of iOS 11, you may find that you can’t change the ringer volume directly by pressing the volume buttons on one side of iPhone. This could be super inconvenient for you who get used to directly adjust the volume of ringtone through volume buttons.
Well, don’t be upset. If you still want to do the thing in the former way, you can still get it back and set your volume buttons to change ringer volume easily. Keep reading to know how to achieve it.
Change ringer volume on iPhone by pressing the side buttons can be easily set. Follow the steps below to give a try. And this method is available for all the iPhone models (iPhone XS/XS Max/XR included) that have updated to iOS 11 or iOS 12.
Step 1. Open Settings app > Scroll down and tap “Sounds/Sounds & Haptics”.
How to Change Ringer on iPhone - Step 1
How to Change Ringer on iPhone – Step 1
Step 2. Under Ringer and Alert, drag the slider to adjust your ringer volume on iPhone.
Step 3. Toggle on “Changed with Buttons” > Then you can easily change your ringer volume by pressing the volume buttons.
How to Change Ringer Volume on iPhone - Step 3
How to Change Ringer Volume on iPhone – Step 3
Don’t miss: How to Make a Song as Ringtone on iPhone X/XS (Max)/XR
That’s all about how to change ringer volume on iOS 11/iOS 12. Now you can easily adjust your ringer volume after reading this post. You can also share this guide with your friends also who have the same problem as they might be looking for this guide.
Roger Smith
Work for iMobie team for 5 years as well as an Apple fan, love to help more users solve various types of iOS or Android related issues.
