How to Clean Out Your Mac
How to clean out a Mac? This iMobie guide will offer you an easy and fast solution to help you clean out your Mac by removing all kinds of junk files.
Joy
Mar. 31, 2016
MacClean – Clean out Your Mac
MacClean – Best Mac Cleaning Software
Download MacClean prior to save your time before reading this guide on how to clean out your Mac.
With time goes by, your Mac can get clumsy because of junk files stored on it. As spring is approaching, besides cleaning out your garage or basement, it's also the very time to clean out your old Mac by removing various kinds of junk files from it.
We have previously talked about how to fix a slow and sluggish Mac. Here in this guide, we will introduce you how to clean out a Mac in a fast and safe way. The tool we will use is a free and professional Mac Cleaning Software, iMobie MacClean.
How to Clean Out a Mac
Recommend Reading: How to Clear All History on Mac >
A brief introduction to MacClean
How to Clean out Your Mac with MacClean
Step 1. Go to download and install MacClean on your Mac. Run it from your Mac Dock or Launchpad.
Step 2. Open MacClean and choose the junk files you want to delete under Cleanup, here take System Junk for example. Then click on Scan button.
How to Clean Out Mac with MacClean – Step 2
Step 3. The scanning time depends on how much junk files stored on your Mac. After the scan finished, you can preview the junk files, select the one you want to remove. Then click the Clean button to clean out your Mac.
How to Clean Out Mac with MacClean – Step 3
Also Read: How to Speed Up Your MacBook >
Cleaning out your Mac should be as easy as 123, and MacClean is the best way to go. Why not free download it to have a try now? Any question on this guide or MacClean is warmly welcomed, meanwhile, don't forget to share this guide with your friends.
