How to Delete Books from iBooks on iPhone
Want to delete books from iBooks but do not know how? This guide offers three methods to help you delete books in iBooks on iPhone 7/6s/6/SE/5s/5c/5/4s.
Joy Taylor Last Updated: Jan. 03, 2020
If you just get one new iPhone 7 or iPhone 7 Plus, you can refer to this guide to make a smooth upgrade to iPhone 7 from old iPhone or Android phone. And also learn some tips to maintain your new iPhone 7/7 Plus.
With the built-in iBooks app, we can easily download books and PDFs straight to your iPhone. If your iPhone is stuffed to the gills with multimedia-rich book files, in this tutorial, we will show you how to reclaim storage space by removing books and PDFs from iBooks on iPhone 6/6s/SE/5/5s and the new iPhone 7/7 Plus.
Delete Books on iPhone 6/6s to Free up Space
1. How to Delete Books from iPhone in iBooks App
You can directly delete books from your iPhone in the iBooks app. Here is how:
Step 1. Find and open the iBooks app on your iPhone.
Step 2. Click on My Books at the bottom bar. Click on Select on the right hand corner, tap on the books you want to remove.
Step 3. Click the red Delete button to remove books in iBooks from iPhone.
How Remove Books from iPhone in iBooks
2. How to Delete Books from iPhone with iTunes
As we all know syncing books with iTunes will erase the existed books on your iPhone, so you can remove the books with from iPhone with iTunes.
Step 1. Lunch iTunes and connect your iPhone 6/6s to computer. Click on the Device button.
Step 2. Choose Books > Sync Books > Selected books > Uncheck all the books (Select no books) > Click Apply.
How to Remove Books from iPhone with iTunes
3. How to Delete Books from iPhone with AnyTrans
AnyTrans is an iOS files manager that allows you to manage your books, audiobooks, contacts, notes, messages, photos, videos, music and more on iPhone/iPad/iPod. You can easily add or remove books from your iPhone in few clicks, and it is also very simple to transfer books from iPhone to iPad/iPhone with AnyTrans. Before deleting the books, it is highly recommended to transfer the books to computer as a backup via AnyTrans. Take a tour with AnyTrans >
Step 1. Open AnyTrans, and connect your iPhone. After AnyTrans recognizes your device, scroll down and click on Books category.
How to Delete Books from iPhone with AnyTrans – Step 1
Step 2. Select the books or PDF files you want to delete, and tap the Trash icon. You can select multiple books also.
How to Delete Books from iPhone with AnyTrans – Step 2
That’s all! You can choose the method you prefer to delete books from iPhone 7/6s/6/SE/5s/5c/5/4s/4. We highly recommend you to have a try on the iOS files manager AnyTrans for it gives you overall control of your iPhone content.
Joy Taylor
Member of iMobie team as well as an Apple fan, love to help more users solve various types of iPhone related issues.
