How to Delete Songs from iPad Air/Air 2 and iPad mini 2/mini 3 Easily
How to delete music from iPad Air/mini? If you want to know a good solution to this problem, you can read this step-by-step tutorial to find a way to delete songs from iPad Air/mini.
May 15, 2015
AnyTrans – Tool for Deleting Songs from iPad Air/mini
AnyTrans – iPad Management Software
Go to download AnyTrans to manage songs on your iPad Air/mini. After reading this guide you will know how to remove songs from iPad Air/mini.
If your iPad Air/mini has run out of space, one of methods to free up space on iPad Air/mini is to delete some music you don't like anymore from devices. You can open up your music app, tap the name of a song from right to left, then see a "delete" button and tap on it to clear the unwanted songs.
When you need to delete many songs from iPad Air/mini, you could only delete these songs one by one with this solution mentioned above. If you want to use iTunes to remove music, you should know that the non-purchased music files on iPad Air/mini will be erased when syncing with iTunes. Is there any other available way for you to delete many songs from iPad Air or mini? To help you solve the problem, this iMobie guide will introduce you a simple way to clear the songs you don't like and free up space on iPad Air/mini.
Can't Miss: How to Remove Videos from iPad >
The Tool We Will Use
AnyTrans is the all-in-one software to transfer and mange the music on your iPad Air/mini. You can use it to selectively and massively delete songs from your iPad Air/iPad mini. With AnyTrans, you can transfer songs from iPad Air/mini to iTunes, to computer, to another iOS device, add songs from computer to iDevice without erasing the existed data. You can create backup for songs on iPad Air/mini before removing them from devices in case that you may re-buy them.
How to Delete Songs from iPad Air or iPad mini with AnyTrans
Step 1. Free download and install AnyTrans on computer, run it, and then connect iPad Air/mini to computer via a USB cable.
How to Delete Songs from iPad Air or iPad mini – Step 1
Step 2. Scroll down on the homepage > Audio > click Music to enter the manage page.
How to Delete Songs from iPad Air or iPad mini – Step 2
Step 3. Preview and select the songs you want to remove, and click the trash icon on the top-right of this window to delete the unwanted songs.
How to Delete Songs from iPad Air or iPad mini – Step 3
Also Read: How to Remove Photos from iPad >
As we can see, it is very simple and direct to remove songs you don't like on iPad Air/mini with AnyTrans, which is compatible with iPad Air/Air 2 and iPad mini 2/mini 3. If you still have any question on mind, please contact our support team via Email, and they will reply to you within 24 hours. If you find this guide is very useful, don't forget to share it with your friends. Why not download it now?
