How to Downgrade Snapchat
Want to downgrade Snapchat to the previous version but find no easy way. Follow the guide to know how to get the old version of Snapchat.
By iMobie | Posted on: Sep. 29, 2018, Last Updated: Oct. 11, 2018
Home > AnyTrans for iOS > App Management > How to Downgrade Snapchat Easily and Quickly
AnyTrans – Excellent App Manager
Want to downgrade Snapchat to the older version? This article is intended to show you an easy way to make it. Keep reading on this post to learn more.
Basically, an app upgrade aims to fix the existing bugs and problems. That’s the reason that app developers usually require us to update the applications to the latest version. But for some users, they prefer the older version. Therefore, we post the article here to introduce how to downgrade an app easily and quickly and here we take Snapchat as an example. Head to know how to downgrade Snapchat on iPhone now.
The Tool for Snapchat Downgrade
AnyTrans for iOS is the tool we want to recommend to help you downgrade Snapchat. Check what AnyTrans for iOS brings to you.
  1. AnyTrans enables you to download apps to a local app library on computer, so that you can downgrade Snapchat of an older version.
  2. If you want to try the new version, AnyTrans supports downloading apps without overwriting the old ones.
  3. With just one click, your apps will be grouped into folders by category or color, automatically, all from a computer.
  4. AnyTrans also helps you find and clean up all the damaged apps icons that you cannot either open them or delete them.
How to Downgrade Snapchat on iPhone
Now get AnyTrans for iOS downloaded and then begin the steps.
Step 1 Launch AnyTrans on your computer and plug in iPhone. Choose Device Manager and scroll down to the category page. Choose Apps option.
How to Downgrade Snapchat – Step 1
Step 2 Select Snapchat and click on Download button to back up the old version of Snapchat to AnyTrans App Library.
How to Downgrade Snapchat – Step 2
Step 3 Switch to App Downloader section and sign in the same Apple ID.
How to Downgrade Snapchat – Step 3
Step 4 Go to App Library to find the old versions of Snapchat you just backed up. Hit To Device button to install the Snapchat old version to your iPhone.
How to Downgrade Snapchat – Step 4
Note that AnyTrans for iOS only enables you to downgrade Snapchat when you have the old version in AnyTrans app library. So back up the old versions of apps to AnyTrans firstly. Get AnyTrans for iOS to start the trial now >
