How to Extract Voice Memos from iPhone to Mac/PC Computer without iTunes
How to transfer voice memo from iPhone to Computer? In this post, we’ll walk you through four easy ways to transfer voice memos from your iPhone to a computer.
Joy Taylor Last Updated: May. 27, 2021
Voice Memo app on iPhone comes in handy for several recording tasks such as important conversation, a live music event, etc. With time, you would probably find yourself with a lot of voice memos using a large portion of your device’s storage. That’s when transferring voice memos from iPhone to computer comes into the picture to help you make some room on the device for the new data. In this guide, we have covered all plausible ways to get voice memos off iPhone.
Further Reading: How to Transfer Voice Memos from iPhone to iPhone >
Method 1: Transfer Voice Memos from iPhone to Computer with iTunes
When it comes to getting voice memos off your iPhone to the computer, the first way that may come in your mind is iTunes. Well, iTunes supports transferring voice memos from iPhone to the computer. Indeed, if you would like to sync voice memos to the computer that you used to sync your iPhone, the transfer jobs become easier and quicker.
So, follow the below steps to learn how to get the job done using iTunes:
Step 1: To get started, connect your iPhone to the computer with the help of a digital cable.
Step 2: Launch iTunes (ensure that iTunes is up-to-date).
Step 3: Click on your device icon and then click the “Music” option.
Step 4: Check the option that says, “Sync voice memos”.
Step 5: Hit on the “Apply/Sync” button.
How to Transfer Voice Memos from iPhone to Computer via iTunes
In a while, your iPhone voice memos will be downloaded to your iTunes library. Then, you can copy memos to anywhere else on the computer you like them stored.
Method 2: Transfer Voice Memos from iPhone to Computer with AnyTrans
You can always take the assistance of the third-party solutions like AnyTrans to migrate voice memos from iPhone to the computer without any hassle.
AnyTrans is a powerful all-in-one iOS manager and transfer tool out there. This tool will let you transfer the content between the iPhone and the computer in just one tap. The best part is that it does the transfer job without erasing the existing data on your iPhone (that could possible with iTunes). Moreover, it even comes in handy to transfer and manage voice memos and other data with ease. In short, it could be the best solution to manage your iOS content.
Below are its key advantages:
  • No technical skills are required to use it.
  • Let you transfer voice memos from iPhone to computer selectively.
  • Support for more than 20 file types.
  • Compatible with iPhone, iPad, and iPod touch and all iOS versions.
  • Works on both Windows PC and Mac.
Get AnyTrans and follow the below steps to learn how to extract voice memo from iPhone to the computer with AnyTrans:
Step 1: Launch AnyTrans on the computer and then connect your iPhone to the computer using a USB cable.
Step 2: Once the software detects your connected device, tap on “Device Manager” and select “More” from the main interface as shown in the below figure.
AnyTrans Overview
AnyTrans Overview
Step 3: Then select the “Voice Memos” and then select the desired voice memos you want to transfer to the computer. After the selection, hit on the “Send to PC” button and let the software complete the transfer job.
Choose Voice Memos
Choose Voice Memos
Method 3: Send Voice Memos from iPhone to Computer Using Email
Transferring voice memos from iPhone to the computer via email comes in handy when you have only a few voice memos to get off your iPhone.
To help you get the job done using email, below are the steps:
Step 1: On your iPhone, open the Voice Memos app.
Step 2: Locate the voice memo you would like to send.
Step 3: Select the target voice memo and click on the “Share” icon and then select the “Email” option.
Step 4: Just follow the onscreen instructions to send the selected voice memo.
Step 5: Access that email account on your computer to download the recently send voice memo on the computer and that’s it.
How to Transfer Voice Memos from iPhone to Computer via Email
Method 4: Transfer Voice Memos from iPhone to Mac with AirDrop
You can also take advantage of AirDrop functionality to transfer voice memos from your iPhone to the Mac with ease. This method comes in handy when you don’t want to use iTunes or any third-party solution to get your voice memos off the iPhone.
For this method to work, ensure that both Wi-Fi and Bluetooth are enabled on your Mac and iPhone. Once ensuring, follow the below steps:
Step 1: On your iPhone, open Voice Memos app and then select the target voice memo you want to transfer to the computer.
Step 2: Click the “Share” icon and wait for your Mac’s AirDrop icon to appear, and then click it.
Step 3: In a while, your selected voice memo will be downloaded to your computer’s Downloads folder.
How to Transfer Voice Memos from iPhone to Computer via AirDrop
That’s how to transfer voice memos from iPhone to computer in four different ways. As you can now clearly see that AnyTrans is the only solution that helps you do the job without any limitation. On top of all, it could do other jobs also such as transferring the content from the computer to the iPhone or from one iOS device to another. So, give a try to AnyTrans now and start managing your iOS content more efficiently like a pro!
