How to Fix iTunes Error 1669 in iOS 12/11/10
Trying to update your iPhone to the new iOS 12 but meeting the iTunes error 1669? Stop looking for solutions cause this guide will offer several troubleshooting tips to fix iTunes error 1669.
By iMobie | Posted on: Sep. 28, 2018, Last Updated: Sep. 28, 2018
Home > AnyTrans > iPhone Transfer > How to Fix iTunes Error 1669
“Hi guys. I tried updating my software to iOS 12 and I encountered an error 1669? My phone is now getting stuck to restore mode and cannot use my phone. I wonder if it is an Itunes issue. Any ideas?”
A user from Apple Community
Nothing can be worse when you get an iTunes error 1669 while connecting and updating your device using iTunes. The iTunes error 1669 can appear during software installation, system upgrading, data syncing, malware infection, or download corruption. Now let’s follow this article and get some solutions to fix iTunes error 1669 without any hassle.
iTunes Error 1669
iTunes Error 1669
How to Fix iTunes Error 1669 Easily
Tip 1. Restart Computer and Reconnect your iPhone
Firstly try some gentle solutions like restarting computer and device. Just disconnect your iPhone/iPad/iPad from the computer and then restart your computer and device.
Fix iTunes Error 1669 via Restarting
Tip 2. Update iTunes to the Latest Version
The iTunes error may be caused by your iTunes version is not compatible with your device. Remember to Check for updates and get the latest version of iTunes on computer.
Fix iTunes Error 1669 via Updating iTunes
Tip 3. Uninstall and Reinstall iTunes on Computer
If restarting and updating iTunes to the latest version can both not work to fix iTunes error 1669, then maybe there are some corruption files in your iTunes file. Try to uninstall iTunes and then reinstall it from the official website.
Fix iTunes Error 1669 via Reinstalling iTunes
Tip 4. Change Another USB Cable
Sometimes this error 1669 can be easily fixed if you change another USB cable, so you’d use the original USB cable with your device.
Tip 5. Run A Malware Scan on Computer
There’s a possibility that the iTunes error is related to some malware confection on your computer, so it damage some files of your software. Just use a malware protection program and conduct a full scan on your computer.
Tip 6. Install Available Windows Updates
Microsoft constantly releases updates to improve windows system so you can install these available updates to fix iTunes error 1669. Click on Start > type in Update in the search box > click on Windows Updates and install updates.
Fix iTunes Error 1669 via Updating Windows
That’s all for how to fix iTunes error 1669 with some simple methods, and you can try them to solve your problem within minutes. Also, you can refer some article to fix similar iTunes error like iTunes error 1667, iTunes Error 0xE8000065 and iTune error 8003. If you have any other workable solutions please share with us below.
