How to Fix iOS 10 Connectivity Issues
This guide will tell you some methods to fix iOS 10 connectivity issues, including cellular connection issue, Wi-Fi connection issue and Bluetooth connection issue.
Sep. 26, 2016
AnyTrans – Manage iPhone/iPad/iPod Content with Ease
AnyTrans – iPhone File Manager
This powerful iTunes alternative can help you manage iPhone/iPad/iPod content easily. Remember to give it a try after you have fixed iOS 10 connection issues.
It has been a few days since the public release of iOS 10, and many users have already updated their iPhone or iPad to this brand new operating system. People are fond of its new features like the Bubble in iMessages, the bedtime wake up alarm and so on.
At the same time, many users also reported quite a few iOS 10 problems after updating their iPhone or iPad, including the connectivity issues. People say that their iPhone show No Service after iOS 10 update, won’t connect iPhone to cellular & Wi-Fi, or have trouble with Bluetooth connection. Here in this guide we will help you fix those iOS 10 connectivity problems. Let’s get it on.
Also Read: Basic Tips to Speed Up iOS 10 on iPhone iPad >
1. How to Fix No Service After iOS 10 Update
Many T-Mobile customers met this problem after the update. The good news is that, Apple and T-Mobile have already pushed a new update settings to solve the issue. So you can go to Settings > General > About to get the fix. The following are some other solutions.
Solution 1: Take out your SIM card and then reinsert it after a few seconds.
Solution 2: Reset Network Settings. Go to Settings > General > Reset > Reset Network Settings.
Related post: Fix No Service After Upgrade to iOS 10 >
2. How to Fix iOS 10 Cellular Connectivity Issue
Solution 1: First turn Cellular off and then turn it on after a few seconds.
Solution 2: Check out Carrier update. Settings > General > About.
Solution 3: Go to Settings > General > Reset > Reset Network Settings.
For more info, please visit: Fix iOS 10 Cellular Data Problems >
3. How to Fix iOS 10 Wi-Fi Connectivity Issue
Solution 1: First go to Settings > Wi-Fi to have a check if it is on.
Solution 2: Reset Network Settings. Then try to connect the Wi-Fi again, and you need to input the Wi-Fi password.
Solution 3: Check out your Wi-Fi router. You can switch off router and then turn it on to have a try.
For more details, you can read: Fix iOS 10 Wi-Fi Problems >
4. How to Fix iOS 10 Bluetooth Connectivity Issue
Solution 1: Go to have a check whether you have turned it on.
Solution 2: Re-pair the iDevice you connect. Settings > Bluetooth > Choose the device you are having issues with > Tap the info button next to the device > Tap Forget This Device.
Solution 3: Make sure your device and Bluetooth accessory are close to each other.
We also prepare you a detailed guide: Fix iOS 10 Bluetooth Problems >
5. Other Methods to Fix iOS 10 Connectivity Issues
Solution 1: Reset your iPhone/iPad. Press and hold down the Home button and wake/sleep button until your device restart with Apple logo.
Solution 2: Restore your iPhone/iPad. Restore your device from iTunes or iCloud. Remember backup your device firstly.
How to Backup & Restore iPhone iPad with iTunes >
How to Backup & Restore iPhone iPad with iCloud >
Solution 3: Downgrade your iPhone or iPad to earlier iOS operating system: How to Downgrade from iOS 10 to iOS 9.3.5 >
Hope this guide can help you fix iOS 10 connection problems successfully. If you have any other idea, you can share it in Comment Section. Now have a try on AnyTrans!
