How to Fix iCloud Restore Not Working Issue
Users who are not able to restore files from iCloud or facing the issue like “restore from iCloud not working”, they must go through this guide. Here, we have mentioned methods that can probably fix this problem.
By iMobie | Posted on: Nov. 16, 2018, Last Updated: Nov. 16, 2018
Home > PhoneRescue > iPhone Data Recovery > How to Fix iCloud Restore Not Working Issue
It is not only you who encountered with iCloud restore problem, but many other iOS users are also facing this problem. Mostly users face this problem when they switch from old iPhone to new and then, want to restore their previous iPhone data to the new device via iCloud. Users, who have no idea why this happening?
There are many reasons that can cause this issue. iOS incompatibility issue is one of these reasons, which means that iCloud restore you are now doing with iOS version is not same iOS version on which you made an iCloud backup. However, we come up with several methods that users can use to fix restore iCloud backup not working.
7 Methods to Fix iCloud Restore Not Working
Method 1. Check Internet Connection
Bad internet connection can be the reason why you are not able to restore from iCloud. Thus, before restoring files from backup, make sure that you have connected your iDevice to a stable Wi-Fi connection. Make sure that it works until iCloud restore process does not complete. You can check your internet connection speed from the settings of your iPhone.
Fix iCloud Restore Not Working via Check Internet Connection
Method 2. Check iCloud Service
If you are getting cannot restore backup the server is a currently unavailable error then it maybe iCloud server or service is down. You can check yourself if the server is down for your system and if it is down, then try to restore iCloud in a few hours. To check the iCloud server status, visit the official Apple system status page.
Method 3.  Restart iPhone
Just, like other software issues, maybe simply restarting an iPhone can also solve this problem. This method has higher chances of fixing the problem as many minor issues get resolved after restarting iPhone.
On iPhone 8 or later
Hold down both volume up or down and power button simultaneously until power slider does not appear. Drag the slider. Press and hold the power button until the Apple logo does not appear.
On iPhone 7 or earlier/ iPad
Hold down the side button until the power slider does not appear on your iPhone screen. Drag the slider and hold the power button until you Apple logo does not appear.
Method 4. Update iOS version
It might be because of bugs in the iOS version which is currently running on your iDevice. Thus, check if the next update is available and if yes, then update it immediately.
Step 1Open the settings app on your iDevice and then, navigate to the “General” section.
Step 2After that, click on the “Software Update” and if the next iOS version is available then download and install it.
How to Fix iCloud Restore Not Working via Update iOS version
Once you updated your iDevice to the latest iOS version, again perform iCloud restore and check now, you receive an error “restore iCloud backup not working” or not.
Method 5. Put iPhone in Recovery Mode
Another method that you can try is putting your iDevice in DFU mode. This method works for many uses and maybe, it also works for you.
Step 1Connect your iDevice to the computer and then, run the latest iTunes version on the computer.
Step 2Now, you need to put your iPhone in recovery mode.
On iPhone 8 or later: Press and release volume up button quickly and follow the same with volume down button. Press and hold side button until iTunes icon does not appear.
On iPhone 7 or 7 Plus: Press and hold the side and volume down button until iTunes icon does not appear.
On iPhone 6 or earlier/ iPad: Press and hold side and home button until iTunes icon does not appear.
Fix “Cannot Restore Backup the Server is Currently Unavailable” Issue
Step 3Once iTunes detect your iPhone in recovery mode, the message will appear either you want to restore or update. Go for restore option.
Step 4After restoring iPhone with iTunes, restore from iCloud backup.
Method 6. Check iDevice Storage
Why iCloud restore not working? It can be because your iDevice storage is running out of space. Therefore, you need to manage some space on your device so that you can easily restore files from your iCloud backup. To free up space on iDevice, follow the below steps:
Step 1Open the settings app on your device and then, go to the “General” settings.
Step 2The, click on the “iPhone Storage” and here, you can manage your device storage by deleted unwanted apps and data.
How to Fix: iCloud Restore Not Working via Check iDevice Storage
Method 7. Fix iCloud Restore Not Working with PhoneRescue
Tried all the above methods and still, not be able to come out of the issue? Then, use third-party software that helps you recover data from your iCloud backup. PhoneRescue for iOS is a wonderful tool for iOS data recovery. With the help of it, you can selectively recover files from iCloud backup with great ease. It supports various file types such as photos, videos, music, app data, and many more.
Here is the detailed step-by-step guide on how to use PhoneRescue for iOS to recover data in iCloud mode:
Step 1First, download and install the software on your computer and then, run it. After that, connect your iDevice to the computer using a cable.
Step 2Thereafter, you will be on the software main interface and here, select the “Recover from iCloud” as shown in the figure.
How to Fix: iCloud Restore Not Working via PhoneRescue - Step 2
How to Fix: iCloud Restore Not Working via PhoneRescue – Step 2
Step 3Sign in with your Apple ID > Select the backup you need > A notification screen will pop up to select file types. Select all data here, and then click OK button > Take some minutes to download it > Click on Right Arrow to scan the backup.
How to Fix: iCloud Restore Not Working via PhoneRescue - Step 3
How to Fix: iCloud Restore Not Working via PhoneRescue – Step 3
Step 4Once scanning is finished, you can preview recovered data and then, select those you want to recover. Finally, you can either save to computer or directly to your iDevice.
How to Fix: iCloud Restore Not Working via PhoneRescue - Step 4
How to Fix: iCloud Restore Not Working via PhoneRescue – Step 4
Hence, we have given possible methods to fix restore iCloud backup not working problem. We hope that our guide helps you to resolve the issue. Among all the methods, it is PhoneRescue which is most recommended to use as it has a higher success rate to recover data from iCloud backup.
