Top 5 Easy Fixes for iPhone iPad Calendar Not Working Issues
This post aims at telling you how to fix iPhone iPad Calendar not working issues. If Calendar on your iPhone/iPad is not working, this guide is exactly what you need.
Elena
Nov. 28, 2017
AnyTrans – Excellent iPhone iPad Calendar Manager
AnyTrans – Best iPhone iPad Calendar Manager
AnyTrans can help you transfer calendars from iPhone to iPhone, from iPhone to iCloud or save iPhone iPad calendars to computer. Do give it a try after fixing issues of iPhone iPad Calendar not working.
There are many issues you might encounter while using Calendar app on iPhone iPad, like iPhone Calendar not syncing with iCloud/Gmail/Outlook, iPhone calendars disappeared. Here is one email we got from one iPhone user.
The Calendar is not working on my iPhone. It worked well, but all of sudden, after putting a new event on my iPhone, the new event doesn’t appear anywhere. Moreover, after adding a calendar event on iCal in my computer, the event shows up everywhere but not iPhone. What to do to fix issues of Calendar not working on iPhone? Please help.
When people say iPhone Calendar not working, the most likely symptom is no change made on iPhone Calendar could be synced to other devices and the change made on other devices can also not be synced to iPhone.
If you are encountering iPhone Calendar not working issues, don’t fret, here in this post, we will show you all potential solutions to fix it. Note that these methods also work for fixing iPad Calendar not working issues.
Don’t Miss: How to Add Music to New iPhone >
iPhone/iPad Calendar Not Working
Top 5 Methods to Fix Issues of iPhone/iPad Calendar Not Working
Here are 5 tips in total to fix iPhone iPad Calendar not working issues. It is suggested to try them one by one.
  1. Make sure you have signed in the same Apple ID on every iOS devices.
  2. Make sure your iPhone/iPad is under good Internet connection. If not, try to switch from cellular data from Wi-Fi or Wi-Fi to cellular data.
  3. Always Save Calendar under iCloud
There are so many calendar service you can choose from, like Yahoo Calendar, Google Calendar, so you probably didn’t set iCloud calendar as the default calendar on your iPhone. iCloud can only sync calendar saved in iCloud Calendars instead of all calendars on iPhone, that’s why you need to set iCloud Calendars as your default.
To set iCloud calendar as your default, please Tap Settings > Contacts > Default Account. Tap a calendar under iCloud and you can make it as your default calendar.
  1. Turn off Apps Requesting Access to Calendar
Go to Settings > Privacy > Contacts, Mails and Calendars. Make sure there is no App requesting access to Calendar. If there are any, turn them off.
  1. Refresh Your iCloud Calendar
This method seems really simple but many people may forget to try. Open the Calendar app and tap the Calendar tab, swipe down on the list to refresh your events and reminders.
Having to many calendar items on iPhone but don’t know how to deal with them? AnyTrans can lend you a big favor in managing calendars. It could help you transfer calendar items from iPhone to iPhone, from iPhone to iCloud or save calendar items to computer in printable and viewable format. Get it now and have a seven-day free trial.
That’s all for how to fix iPhone iPad Calendar not working. If you are encountering other Calendar issues, please don’t hesitate and leave comments below. By the way, don’t forget and download AnyTrans to have a 7-day free trial.
