How to Fix iPhone Stuck in Boot Loop
iPhone stuck in boot loop? Don't worry, here in this post, a few methods to fix iPhone stuck in boot loop are introduced to help you.
Lydia
July. 12, 2017
PhoneRescue – Help You Restore iOS System with Ease
PhoneRescue – Excellent iOS System Recover Tool
PhoneRescue – iOS data recovery could help you restore iOS system with great ease. Download it right now if you decide to fix iPhone stuck in boot loop by restoring iOS system.
Apple launched iOS 11 beta a few months ago and many users now can't wait to update their iPhone for more new features. However, recently, we have got emails from many users claiming that their iPhone stuck in boot loop while updating. After many tests, we came up with four solutions for iPhone stuck in boot loop issue. If you are suffering from this notorious issue, please follow us and fix iPhone stuck in boot loop.
Method 1. Hard Reset
No matter what problem you are encountering, hard reset is always helpful. After a hard reset, there is a great opportunity that iPhone stuck in boot loop issue would be fixed.
To do hard reset, all you need to do is pressing and holding the Power button and Volume Down button (for iPhone 7/7s) or Power button and the Home button (for other iPhones) at the same time.
Method 2. Use Volume Up Trick (Jailbroken iPhone Only)
iOS updating is not the only cause of boot loop. For jailbroken iPhone, most boot loop cases are probably caused by a broken or incompatible jailbreak tweak. To get jailbroken iPhone out of boot loop, please press Volume Up button while the iPhone is booting up. You should then be able to access the lock screen again. Run Cydia and uninstall the tweak caused boot loop, your iPhone would no longer stuck in boot loop.
Method 3. Reset Battery
Resetting battery could help you fix many iPhone stuck in boot loop issues on both jailbroken and unjailbroken iPhones without data loss. However, it could be risky, please don't try this method without supervision of an expert.
What you will need are two screwdrivers, a suction cup and a plastic pull tool.
Before start, please press the Home button and Sleep/Wake button until Apple logo disappear. (For iPhone 7/7s, please press Volume Down button and Sleep/Wake button.) Remove the two screws on the left and right side of the charging port. Put the suction cup on the iPhone screen, lift the screen just a little bit. Then remove the two screws that locks the battery connector to the battery retaining bracket, pop the battery connector up, wait a few seconds, then put everything back. Try to restart your iPhone, and see if your iPhone still stuck in iPhone boot loop.
Method 4. Restore iPhone Operating System with PhoneRescue
If none of the methods above work for you, restoring iPhone operating system is the last way to fix iPhone stuck in boot loop issue.
When it comes to restoring iPhone operating system, the first tool pops to your mind is iTunes. Indeed, iTunes is a nice tool to restoring iPhone operating system. However, as we all know, restoring iPhone operating system with iTunes would cause data loss. Is there one tool that could restore iPhone operating system without data loss?
Definitely YES! PhoneRescue is developed to help both Android and iOS users to recover lost data and PhoneRescue – iOS data recovery, with new function added, could help users restore iPhone operating system without data loss. Now, let's see how to use PhoneRescue – iOS data recovery to fix iPhone stuck in boot loop by restoring iPhone operating system.
Step 1. Free download PhoneRescue – iOS data recovery, (choose download for iOS), launch it on your computer. Connect your iPhone with computer via an USB cable.
Step 2. Select iOS Repair Tools and click the arrow button on the down right corner to continue.
How to Fix iPhone Stuck in Boot Loop via PhoneRescue - Step 2
Step 3. Choose Advanced Mode, click the arrow button on the down right corner again. Check your device info then click Download to download package for repairing iOS system. After downloading, PhoneRescue would repair your iPhone automatically.
How to Fix iPhone Stuck in Boot Loop via PhoneRescue - Step 3
1. Please shut down iTunes while running PhoneRescue – iOS data recovery.
2. Normally, boot loop cases are caused by system which Advanced Mode could easily fix, however, if the boot loop is caused by hardware, then you should choose Standard Mode to restore iPhone operating system.
That's all for how to fix iPhone stuck in boot loop. We hope now you have fixed iPhone stuck in boot loop issue. If you find this guide helps, please share it with others to help more people. By the way, if you mistakenly deleted data on your iPhone, PhoneRescue – iOS data recovery could also lend you a favor. Take a tour with PhoneRescue – iOS data recovery now >.
