How to Fix iPhone iPad Slide to Unlock Not Working
Slide to unlock not working on your iPhone iPad? Here in this post, we will show you detailed steps to fix this problem.
by iMobie Follow @iMobie_Inc
AnyTrans – Excellent iOS Content Manager
AnyTrans could lend you a helping hand to transfer data from iPhone to iPhone. After fixing slide to unlock not working issues, do give it a try if you need to upgrade to new iPhone.
Q: Good evening, everyone. My iPad won't slide to unlock. Nothing happens when I try to slide it. Why my slide to unlock not responding and how to fix it? Any ideas are appreciated!
A User from Apple Discussion
Fix iPhone Notifications Not Working
Slide to unlock not working actually has something to do with the apps and systems. It can also happen quite sudden out of hardware failure. No matter how iPhone iPad won't slide to unlock issues happen, try the solutions below and see if you can fix it.
How to Fix iPhone iPad Won't Slide to Unlock
Since there are many reasons causing iPhone iPad won't slide to unlock issues, solutions may vary from each other. We suggest you try them one by one.
1 > Fix iPhone iPad Won't Slide to Unlock by a Hard Reset
Press and hold the Sleep/Awake button and the Home button or Volume Down and Home button (iPhone 7 and later) simultaneously, don't let it go until the Apple logo appears. This method works for most users.
2 > Fix iPhone iPad Won't Slide to Unlock by Cleaning Your Hands/Screen
We love moistures, especially in winter. However, this is also one of the causes of iPhone iPad won't slide to unlock issues. Just try to clean your hands and the screen, see if slide to unlock not working issue has fixed.
3 > Fix iPhone iPad Won't Slide to Unlock by Restoring iPhone iPad
Restoring iPhone iPad can fix nearly all problems caused by software. Before following the steps below to restore iPhone iPad, please make sure you have the latest version of iTunes and there is a previous iTunes backup on your computer.
Step 1. Connect your iPhone to computer via an USB cable, launch iTunes if it doesn't pop out automatically.
Step 2. Click the device tab, go to Summary. Click Restore Backup. Select one previous backup and confirm, your device would soon be restored.
Fix iPhone iPad Won't Slide to Unlock by Restoring - Step 2
4 > Fix iPhone iPad Slide to Unlock Not Working by Asking Siri to Open Apps from Lock Screen
If none of the methods above work for you, then slide to unlock not working issues are caused by the hardware. If you need to unlock your iPhone iPad urgently, you can fix this problem temporarily by asking Siri to open an app from lock screen.
Press the Home button and activate Siri. Say open Email, or open Settings, or any app you like, enter your password. Once you are in the app, press Home button again and you can get back to the main screen.
5 > Go to the Apple Store
There are specialists in Apple Store and they can surely fix it. Even though it could be expensive, but if your iPhone is still under warranty, then it shouldn't be a problem.
Bonus Tip: How to Transfer Data from Old iPhone to New iPhone
Even though a new iPhone 8 and iPhone X may cost as much as $699 and $1000, many people would still like to empty wallet just for one of them. If you also bought a new iPhone 8 (Plus)/X, before upgrading to new iPhone 8 or iPhone X, you should realize the data on your old iPhone is just as precious as the new iPhone.
Then after purchasing a new iPhone, how to safely transfer them from old iPhone to new iPhone? Neither iTunes nor iCloud could backup all data. For many green hands, they can be quite confusing. Here in this bonus tip, we will show you a super easy-to-use tool - AnyTrans to do you a favor.
What Is AnyTrans for
Developed by iMobie team, AnyTrans is one the most easy-to-use iOS data managers. It could help you directly transfer data from old iPhone to new iPhone without tedious backing up and restoring process. Here are reasons why you need the help of AnyTrans to safely move data from old iPhone to new iPhone.
1. It supports transferring 22+ kinds of data like contacts, messages, from old iPhone to new iPhone, that is to say you will never miss any data if you try AnyTrans to transfer data from old iPhone to new iPhone.
2. It allows you to selectively transfer data from old iPhone to new iPhone.
3. It could help you extract and view data from iCloud and iTunes backup, it could even help you download data from backups to computer and restore to your iPhone.
4. It saves you a lot of time. Within 5 minutes, you can transfer a few gigabytes of data from old iPhone to new iPhone.
5. It is developed by Apple-trusted developer. It is also McAfee and Norton secured. With such a green software, you will never worry about any data loss or information leakage.
Overview of iMobie AnyTrans
For detailed steps of transferring data from old iPhone to new iPhone, please refer to How to Transfer Everything from Old iPhone to New iPhone >
That's all for how to fix iPhone iPad won't slide to unlock and one easy method of transferring data from old iPhone to new iPhone. If you find this post helpful, please do share it with others. Any questions? Please do leave them in the comment column, we will reply as soon as possible. By the way, if you need to upgrade to new iPhone, please give AnyTrans a try.
More iOS 11 Upgrade Related Articles:
Join the Discussion on Fixing Slide to Unlock Not Working
