How to Fix iTunes Error 1012
The unknown error 1012 appears when your iTunes goes wrong. If you are looking for solutions to iTunes error 1012, some easy tips in this guide can help you address it.
By iMobie | Posted on: Aug. 10, 2018, Last Updated: Sep. 28, 2018
Home > PhoneRescue > iPhone Data Recovery > How to Fix iTunes Error 1012
iTunes is really a complicated software that always generates various errors, such as error 1603, error 1004, error 1012, etc. In this guide, we are going to talk about iTunes error 1012. The appearance of error 1012 represents that there’s a hardware issue exists on your computer. You must don’t want to be bothered by this annoying issue. Therefore, in order to help you fix this unknown error, we have prepared 6 ways for you. Now you can follow us to get rid of iTunes error 1012.
6 Solutions to iTunes Error 1012
Solution 1. Quit iTunes and Reopen It.
This is the easiest way to fix this iTunes error 1012. Sometimes, iTunes may not connect to the server properly, but once you restart it again, it may work with no problem.
Solution 2. Make Sure Your Internet Connection is Fine.
No internet connection or internet connection is weak will lead to various problems, including the iTunes error 1012. Therefore, you can reconnect your internet to have a try.
Solution 3. Check Your USB Cable.
You can go to check if your USB cable is damaged or loose, if it is, just changes a new one to have a try. Besides, remember to use the Apple original USB cable for sometimes, non-original USB cable cannot be identified by your computer.
Fix iTunes Error 1012 By Checking USB Cable
Solution 4. Ensure your computer is reliable. If it is not, just change a reliable one.
Solution 5. Check Your Third-party Security Software.
Security software created by companies other than Apple may prevent iTunes from connecting to an Apple server or device. Occasionally, you may see numeric error messages when you synchronize, update, back up, or restore your device. So you can go to turn the security software off temporarily to have a try.
Solution 6. If all the solutions above can not help you address iTunes error 1012, just contact the Apple Support to help you.
Bonus Tip: Easily Restore Data with iTunes Alternative
As you all know, there’re a lot of errors that may be generated by iTunes. When errors occur, you have to try various ways to fix it. The more ways you try and the more possible to lose data. If you, unfortunately, met data loss on your iDevice and cannot use iTunes to restore those lost data, you can try this iTunes alternative – a trusted iOS data recovery tool to get your lost data back.
iTunes Alternative - PhoneRescue for iOS
iTunes Alternative – PhoneRescue for iOS
With the above solutions, we hope you can fix the iTunes error 1012. If you have any question about them or have other new and possible solutions, you can leave your messages in the comments.
PhoneRescue ® for iOS
Recover your deleted iPhone iPad files with the highest success rate, no matter whether you have backups or not!
  • * 100% Clean & Safe
5,716,299
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
