5 Tips to Fix iTunes Error 1643
Have you ever received an alert message about iTunes error 1643 in the process of updating or restoring? Wondering why it happens and how to fix it. Keep reading this post and get some tips to fix iTunes error 1643.
By iMobie | Posted on: Sep. 18, 2018, Last Updated: Sep. 18, 2018
Home > PhoneRescue > PhoneRescue for iOS > 5 Tips to Fix iTunes Error 1643
PhoneRescue – iOS Data Recovery
Based on custom-designed technologies, PhoneRescue comes as the ONLY lifesaver to safely rescue you from any iOS data disasters at the first moment. photos, messages, contacts, or just any piece of iPhone data you can’t live without, we bring them all back for you, in the most straightforward, efficient and secure manner.
Have you ever received an alert message about error code while using iTunes? Do you know Apple expose dozens of these kinds of error codes? And different error codes show respective reasons associated with iTunes, devices or other something. This case is relevant to iTunes error 1643. First, you have to know iTunes error 1643 always appears when you update systems or restore your device. So why does it happen? Probably there is something wrong with your USB connection, USB cable, USB port, or computer. Then you can follow the 5 tips below to fix iTunes error 1643.
Method 1: Update The Latest iTunes
You’d better get the latest version of iTunes. Go to ‘Help’ and check whether your iTunes is up to date. If no, please upgrade it to the latest version with the active and stable internet.
Method 2: Check USB Cable and USB Port
Use another USB cable in case your old one is broken. Or you are using a third-party USB cable, find and use the Apple one. Please try to connect other USB ports on the computer. Notice that don’t plug into your keyboard.
Method 3: Disconnect Other Devices from Your Computer
If you connect any other USB devices simultaneously, please disconnect them and just leave one device you are using.
Method 4: Restart Your Computer
Many glitches and errors in the process of restoring and updating can be solved by restarting the computer. So just give a try.
Method 5: Check Third-party Security Software
Check whether your third-party security software including antivirus program and firewall prevents Apple’s servers from completing the update/restore process. To temporarily turn off or uninstall these security software.
Restore Data from iTunes Backup with iTunes Alternative
If you try all these tips, and the error code doesn’t disappear. You’d better try an alternative software – PhoneRescue for iOS to restore your iPhone. With PhoneRescue for iOS, you can easily find your lost data and files in a flash, also you just need 3 clicks to recover all your data without tech knowledge. More than iTunes, you can retrieve your data from your iPhone directly and iCloud. So just download it and have a try.
Step 1Install PhoneRescue and connect your iDevice. Choose ‘Recover from iTunes Backup’ and click ‘Next’ button.
Restore Data from iTunes Backup with iTunes Alternative - Step 1
Restore Data from iTunes Backup with iTunes Alternative – Step 1
Step 2Select an iTunes backup and choose the types of data you want to recover.
Restore Data from iTunes Backup with iTunes Alternative - Step 2
Restore Data from iTunes Backup with iTunes Alternative – Step 2
Step 3Select certain files you want to restore and click ‘Recover to device’ or ‘Recover to Computer’ you like.
Restore Data from iTunes Backup with iTunes Alternative - Step 3
Restore Data from iTunes Backup with iTunes Alternative – Step 3
That’s all about iTunes error 1643 and its solutions. Have a try. If they don’t work, download PhoneRescue for iOS to manage and restore your iOS data. It helps you restore your files fast, safely and selectively without iTunes and iTunes error. If you still have question about iTunes error 1643 or PhoneRescue, please leave your comments.
Christian Chus
PhoneRescue ® for iOS
Recover your deleted iPhone iPad files with the highest success rate, no matter whether you have backups or not!
  • * 100% Clean & Safe
5,716,299
Users Served
