5 Ways to Fix iTunes Error 1645
If you encounter the problem about iTunes error 1645 when you update or restore iOS device with iTunes, you may don’t know what it is, why it occurs and how to deal with it. Keep reading this post and your query will be completely interpreted. This post will give 5 ways to fix iTunes Error 1645.
By iMobie | Posted on: Sep. 26, 2018, Last Updated: Sep. 26, 2018
Home > PhoneRescue > iOS Data Recovery  > 5 Ways to Fix iTunes Error 1645
PhoneRescue – iOS Data Recovery
Based on custom-designed technologies, PhoneRescue comes as the ONLY lifesaver to safely rescue you from any iOS data disasters at the first moment. Like photos, messages, contacts, or just any piece of iPhone data you can’t live without, we bring them all back for you, in the most straightforward, efficient and secure manner.
As known to all, it’s quite simple to restore or update iPhone with iTunes, however, you’ll mess up if iTunes errors appear to you. Especially something is not very common, such as iTunes error 1645. In fact, there are many kinds of iTunes errors names that contains the details of the error, including why it happens, which system component or application malfunctioned to cause this error along with some other information. iTunes error 1645 is one of them.
So what causes does it occur? It always happens when there is malfunction in your system operation which may be commonly caused by incorrect or failed installation, unloading of software that may have left invalid entries in your Windows registry, consequences of virus or malware attack, improper system shutdown due to a power failure, as well as accidentally deleting a necessary system file or registry entry.
How to Fix iTunes Error 1645 with 5 ways
Then 5 methods are going to be provided in detail for you. Keep reading, follow the tutorial below step by step.
Solution 1: Restart Your iPhone and Computer
Though iPhone or computer restart is quite simple because you just need to press the sleep/wake button, sometimes it really works. Have a try.
Fix iTunes Error 1645 - Restart iPhone
Fix iTunes Error 1645 – Restart iPhone
Solution 2: Change Your USB Cable and USB Port
In case your broken or third-party cable/port affects the communication, try using a brand new Apple cable/port.
Solution 3: Disconnect Other Devices
If you connect other devices to your computer, please disconnect them and only keep one you need.
Solution 4: Shut Down Virtualization Apps
Your virtualization may cause the issue in the communication between your iDevice and your computer if it’s running. Therefore, shut down VMware and Parallels when you connect your iDevice to the computer.
Solution 5: Update, Turn off or Uninstall Your Security Software
Also, security software has the negative effect on connection between your iDevice and your computer. At this time, firstly update your security software. If the error doesn’t disappear, see if it works by turning off or even uninstalling your security software.
Fix iTunes Error 1645 - Check Security Software
Fix iTunes Error 1645 – Check Security Software
Bonus Tip: Restore iOS Device without iTunes
As you know, there are a lot of error codes that may be generated by iTunes. You have to try many different solutions as you encounter one of them. What’s worse, you have to take the risk of data erasing when you operate some of those methods. Therefore, you can restore your iOS data with an iTunes alternative. PhoneRescue for iOS is highly recommended. It’s a user-friendly data recovery tool. Within just 3 steps, you can restore almost all your iOS data completely. Moreover, it enables you to restore data from iOS device directly as well as iCloud. Why not download it and have a try.
Fix iTunes Error 1645 - Restore iOS Device without iTunes
Fix iTunes Error 1645 – Restore iOS Device without iTunes
You must have detail information about iTunes error 1645 after reading this post, including the definition and causes of it. More importantly, you learn about 5 methods to fix iTunes error 1645. So try them step by step next time you encounter it.
Christian Chus
