Four Ways on How to Fix iTunes Error 3002
When updating iPhone or iPad with iTunes, sometimes users might see a warning error message showing iTunes error 3002 during the process. Once this error message is appear, the updating process will be forced to stop. Then how to fix iTunes error 3002? Don’t worry, this post will give you answer.
By iMobie | Posted on: Sep. 26, 2018, Last Updated: Sep. 26, 2018
Home > AnyTrans > AnyTrans for iOS > Four Ways on How to Fix iTunes Error 3002
Q: Hello, I am getting iTunes error 3002 showing “The iPhone iPhone could not be restored. An unknown error occurred (3002/16.xx)” every time I try to restore or update my iPhone. I have tried Shift + Restore as well as Shift + Upgrade combo but it doesnt work? Any ideas? Thanks.
This is an iPhone user saying that he has faced with an iTunes error 3002 problem when he tried to restore or update his iPhone. iTunes error is a common problem for iOS users. Sometimes it happens when they update or restore iPhone through iTunes, sometimes it happens when they downloading media with iTunes. No matter how and when iTunes error happens, it always drives iPhone users crazy because it’s hard for them to find an quick and effective method to solve the problem.
In order to help those users who have stuck on iTunes error 3002, we have listed several ways for them to solve the problem. Let’s check it out.
Method 1. Re-install iTunes
iTunes error 3002 happens because of iTunes can’t communicate with Apple’s software update server. So if you have faced with this problem, install the latest version of iTunes and try to update or restore again.
Method 2. Check and Disable Firewall and Security Software
If you have firewall or third-party security software installed on your computer, temporarily disabled these software and try again. Because some firewall or third-party software might block the connection of your computer towards Apple’s server.
Method 3. Check Internet Connection
iTunes error 3002 might also caused by network settings, check your internet connection can be a solution. If your computer uses a managed network, refer to your network administrator. Proxies, firewalls, and other network security measures can cause these errors. If necessary, find a different network connection to restore the device.
Method 4. Check Your Hosts File
Checking hosts file can help you to make sure that your computer could connect to the update server.
If you are in a Windows computer, please follow these steps from Microsoft Support Site to reset the hosts file back to default.
If you are in a Mac, try these following steps.
  1. Go to Finder > Applications > Utilities.
  2. Open Terminal, type “sudo nano  /private/etc/hosts” and press Return.
  3. Enter your computer log in password and press Return.
  4. After entering password, the Terminal will display hosts file. Navigate using the arrow keys and look for an entry containing “gs.apple.com”. Add the ‘# ’ and a space to the beginning of the gs.apple.com entry.
    How to Fix iTunes Error 3002 Image Credit: Apple.com
  5. Press Control-O to save the file.
  6. Press Return when asked for the filename.
  7. Press Control-X to exit the editor.
  8. Restart your Mac.
By now you might have fixed iTunes error 3002 with these methods above. If you still have problem on it, please contact Apple for more help. Any ideas or comments about iTunes error fixing are welcomed.
AnyTrans ® for iOS
  • * 100% Clean & Safe
11,452,517
Users Served
