How to Fix YouTube Not Loading Error
If the YouTube service is not loading on your device and you are wondering “why is YouTube not loading”, the following guide offers some of the ways to fix the issue so that the service loads and you can start watching your favorite videos. Read on to find out.
Author Avatar Joy Taylor Last Updated: Sep. 17, 2021
The YouTube platform can be accessed in various forms from your devices and you can always choose the form that is most convenient for you. You can access it from an app, a browser, or even from a smart television to watch your favorite videos. Sometimes, it happens that YouTube does not load no matter what you try on your devices. If that’s the case with you, don’t worry as there are many other users who face the same issue.
When YouTube stops loading, you start wondering “why is my YouTube not loading”. There could be several factors responsible for the issue and there are a few methods that you can apply to see if they help resolve the issue on your device. In the rest of the guide below, you are going to find out some of the available fixes for the YouTube not loading issue on your device. Let’s check them out:
Method 1. Reboot Your Device
If YouTube has suddenly stopped loading on your device, the first thing you will want to do is reboot whatever device you are trying to access YouTube from. Whether it is an iPhone, an iPad, an Android device, or even a smart TV, just reboot it and then relaunch the YouTube service.
Turn off and on your device
When the service relaunches, it should start loading without any issues. If that did not work for you for some reason, check out the other methods below and they might be able to help you out.
Method 2. Check Your Connection to the Internet
Since YouTube is completely dependent on Internet, you must make sure your Internet is active and is working all the time. Soon as it stops working, the service will stop loading as well and your viewing experience will be interrupted.
Ensure the Internet connection is working
Therefore, have a look at your Internet modem and see if it is working properly. If it is not, contact your Internet service provider to help you fix the issue.
Method 3. Ensure the YouTube App Has Internet
Some of the devices, such as an iPhone, come with the option to restrict data usage for certain apps. If you are using the YouTube app on a device where the device has restricted data usage, the app will not be able to connect to the Internet and as a result, it will load nothing in it.
Enable Internet for the YouTube app on your device
You can check the data restrictions on an iOS-based device very easily. Just open the Settings app, find and tap on YouTube, and ensure the Mobile Data option is turned on. It will make sure the service loads even when you are not connected to a WiFi Internet connection.
Method 4. Update the YouTube App on Your Device
If the version of the YouTube app that you are using on your device is an old one, you will need to update it to the latest one from the respective app store of your device.
Install the latest version of YouTube app
To update the YouTube app on an iOS-based device, launch the App Store and tap on Updates at the bottom. Find the app named YouTube and tap on Update next to it and it will update the app for you.
To update the app on an Android device, open the Play Store app, search for and tap on YouTube, and tap on the Update button. It will download and install the latest version of YouTube app on your device.
Method 5. Reinstall the YouTube App on Your Device
If updating the YouTube app did not do the trick for you, you may want to first completely uninstall the app from your device and then reinstall it. It can be easily done by following the following steps.
On an iOS device, tap and hold on the YouTube app and tap on X to uninstall the app. Then, open the App Store, search for and tap on YouTube, and tap on the Download icon to reinstall the app on your device.
Uninstall and install YouTube app on your device
On an Android device, tap and hold on the YouTube app and drag it to the trash icon. Once the app is uninstalled, launch Play Store, search for and tap on YouTube, and tap on the Install button to install the app on your device.
Method 6. Reduce the Quality of Video
One more thing you can try to make YouTube load videos is to reduce the quality of videos that you are watching on your devices. If you are watching videos, say in 720p, you can reduce it to 240p and see if that helps resolve the issue.
It can be easily done by tapping the options button and changing the resolution to a lower one.
Method 7. Remove Firewall Restrictions for YouTube
If you happen to use a firewall app on your device, it could have imposed restrictions on how and when the YouTube platform can use your Internet connection. If that’s the case, get rid of the firewall app on your device and see if YouTube loads successfully then.
The above methods should work even when you face the “YouTube keeps saying error uploading video” issue on your device.
YouTube not loading is one of the issues you can face anytime and the above solutions will help you get rid of the issue as soon as possible. We hope it helped you out with the issue and you are now able to load YouTube without any issues.
