How to Not Show Messages on iPhone Lock Screen
Are you new to iPhone world and don’t know how to not show messages on iPhone? Then, you can refer to this guide as here we have given the detailed guide on hiding messages from iPhone lock screen.
By iMobie | Posted on: Oct. 25, 2018, Last Updated: Oct. 25, 2018
Home > PhoneRescue > iOS Data Recovery > How to Not Show Messages on iPhone
An iPhone has inbuilt feature for message preview on its lock screen. For some iPhone users, it’s a great feature as they can see what is written in the message without unlocking their iPhone. However, this feature for some iPhone users is like breaching their privacy. That’s why they want to disable text message preview feature so that no one can be able to read their messages unless he or she knows their iPhone passcode. In this guide, we have mentioned 2 methods with the simple and detailed process on how to not show messages on lock screen iPhone.
How to Not Show Messages on the iPhone Lock Screen
There are two ways to hide the message preview on the iPhone Lock screen. Here, we will discuss both the ways in detailed. No matter which iPhone model you are using, the below-mentioned methods work for every iPhone model.
Method 1: Turn off the Message Preview
Step 1 On your iPhone, navigate to the “Settings” app and then, go to the “Notifications” option.
Step 2 Thereafter, move to the “Message” option and then, look for the “Show Previews” option. Once able to find it, disable it.
How To Not Show Messages Preview on iPhone via Message Preview
Method 2: Turn off the Notifications Preview
If you don’t want to show the hidden content of any notification or alerts that you will receive on your iPhone lock screen, then go for this method. It will also hide the message preview. Follow the below simple steps on how to not show message preview on iPhone.
Step 1 Open the “Settings” menu and then, navigate to the “Notifications” option.
Step 2 After that, tap on the “Show Previews” option and then, tap on the “When unlocked” if you don’t want to show message preview when your iPhone is locked. Choose “Never” if you to completely hide message preview.
How To Not Show Messages on iPhone via Notifications Preview
Thus, in this guide, we have covered every possible method on how to not show messages on lock screen iPhone. You can select any of the above-mentioned methods as per your choice as both the methods are easy to perform. For iPhone users who want immense privacy for their messages, this iPhone built-in feature is amazing. So, turning off the message preview on the iPhone lock screen is a great way to avoid others reading your personal message. This feature is available for every app notification that you have on your iPhone.
