Want to print iMessages on your iPhone X/8/7/6s/6? Read the guide to get an easy-to-use helper to print iMessages from iPhone X/8/7/6s/6/SE/5s/5. The contact info, attached pictures and sent date in iMessage history are included.
To backup iMesssages on iPhone, there are various choices. You can use iCloud to back up iMessages to iCloud, or use iTunes to create a full backup to save iMessages from iPhone. For some users, you may prefer to print iMessages from iPhone for backup.
How to print iMessages? Taking a screenshot of the iMessages you need and then having the screenshot printed is a way to go. But obviously this only just applies to the situation in which you have a small number of iMessages to print. To print mass of iMessages from iPhone X/8/7/6s/6/SE/5s/5, an excellent helper called AnyTrans is highly recommended to you.
Can Miss: Everything You Should Know about AnyTrans Crack >
As the name suggests, AnyTrans is specially made for iOS users to manage your iPhone, iPad, iPod, and even iTunes and iCloud content in a handy way. With AnyTrans, you can export iMessages from iPhone to computer and then have them printed.
Before you print iMessages from iPhone, you need to firstly get AnyTrans downloaded on your Mac/PC computer to export iMessages from iPhone X/8/7/6s/6/SE/5s/5.
Step 1 Launch AnyTrans on computer and click the Device tab on the homepage. Scroll down to the category page and select Messages option.
How to Print iMessages from iPhone – Step 1
Step 2 Click the Settings button. Select the output format for the iMessages you want to export to print, like HTML, TEXT or PDF, and click Select to set up output folder. Then click the Save button.
Print iMessages from iPhone – Step 2
Step 3 Have a preview of the iMessages on your iPhone and select what you want to print. Click To Computer button to export them to Mac or PC.
How to Print iMessages from iPhone – Step 3
Step 4 View the exported iMessages on computer and have them printed with printer.
AnyTrans is a powerful iDevices content manager, available to transfer various files and data between iOS devices and computer, between iOS devices. Moreover, the tool enables you to manage your iTunes and iCloud backup without many limitations. Get it installed to have a try >
