How to Print Text Messages from LG Phone
Want to print text messages from LG but do not know how? This guide will tell you how to print text messages from LG phone with ease.
By Alexis Hay | Posted on: Mar. 09, 2018, Last Updated: Feb. 14, 2019
Home > AnyTrans for Android > LG Data Transfer > How to Print Text Messages from LG Phone
For legal or personal reasons, you want to print text messages from LG phone. However, it seems quite difficult to make it, because you do not know how to export the messages and print them through a computer. Unlike photos or songs, which you can easily copy from phone to computer when you plug in your phone, but you just cannot find the messages.
Generally, the text messages are stored in the internal flash card that you cannot access directly. So to export the messages, a third-party data transfer tool is needed, that’s AnyTrans for Android.
The Tool You Will Need
1. Your LG phone and its USB cable.
2. Computer with a printer connected.
3. AnyTrans for Android – one professional Android data management tool, which can help you export text messages from LG phone to computer in HTML or TXT format. Lets you preview and select the messages you need.
AnyTrans for Android supports all LG phone models, including LG G4/G5/G6, LG V10/V20/V30. How about give it a try? Download it now and follow the steps below to print your LG phone messages.
Step 1 Download, install and launch AnyTrans for Android > Connect your LG phone to computer via USB cable.
Step 2 Go to category management page > Choose Messages.
How to Print Text Messages from LG Phone – Step 2
Step 3 Preview and select the messages you need > Click Settings button to set the output format and export path > Click Send to Mac/PC to start transferring.
How to Print Text Messages from LG Phone – Step 3
Step 4 Print out the exported text messages by using the printer.
Besides messages, AnyTrans for Android can also help you export contacts, messages, call log, calendar, photos etc. without effort. Also supports computer to phone transfer & phone to phone transfer, just give it a try to take complete control of your Android data.
Alexis Hay
Member of iMobie team, a great lover of iDevices. Always enjoy helping to solve all kinds of iOS and Android problems.
AnyTrans ® for iOS
  • * 100% Clean & Safe
11,452,517
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
