How to Rebuild iTunes Library in Minutes
My computer crashed so my entire iTunes library is lost. How can I rebuild iTunes library on my new computer? Read this post to get a solution.
May 17, 2016
AnyTrans – Quick Way to Rebuild Your iTunes Library
AnyTrans – Reliable iTunes Library Recover
AnyTrans is made to manage your iOS content as well iTunes library. Download AnyTrans and use to rebuild your iTunes library on PC or Mac after reading this guide.
The iTunes library on our home computer saves most of our media files – music, movies, ringtones, and more. It takes your time, energy and money to build a comprehensive iTunes library. But it is possible that your entire iTunes library is gone because of computer crash or disk failure.
If you have synced your iPhone to iTunes regularly then it will be much easier to re-create your iTunes library by transferring things back to iTunes with some iOS transfer tool.
Can't Miss: How to Fix Airdrop Not Working on iPhone/iPad >
The Tool We Need to Rebuild iTunes Library
AnyTrans is only thing we need to rebuild iTunes library, which works on PC and Mac computer and is compatible with all iPhone, iPad and iPod models.
  • Rebuild iTunes library on any computer by transferring data from iPhone/iPad/iPod to iTunes in one click.
  • Support transferring music, movies, ringtones, audiobooks, voice memos, books, and more back to iTunes library.
  • Extract iTunes library and sync media files from iTunes to iPhone without wiping existing data.
  • Enables you to transfer music and more from iPhone to iPhone directly.
How to Rebuild iTunes Library in 3 Steps via AnyTrans
Step 1. Download AnyTrans and install it on your PC or Mac. Open AnyTrans and connect your iPhone to computer via USB cable.
Step 2. On the homepage of AnyTrans, click the Content to iTunes shortcut button. This will allow you to rebuild iTunes library by transferring media files from your iPhone back to iTunes quickly.
Rebuild iTunes Library via AnyTrans
Step 3. Choose the files you want to get to iTunes library, and then click Start Transfer icon.
Also Read: How to Sync iPhone to iTunes >
Rebuilding iTunes library with AnyTrans is easy and quick, and it also enables you to sync data from iTunes to iPhone without erasing any data. Now download it to have a try >
