How to Recover Deleted Contacts from Android Phone with Ease
Want to restore deleted contacts on Android phone but don’t know how? Read this guide to see how to recover deleted contacts from Android phone with ease.
By iMobie | Posted: Feb. 28, 2018, Last Updated: Feb. 28, 2018
Home > PhoneRescue > PhoneRescue for Android > How to Recover Deleted Contacts from Android Phone
Contacts means a lot for us, but contacts loss happens here and there in our daily life. It can be quite annoying and inconvenient no matter you lose all the phone numbers or just one important customer’s info. So is there any way that can help you recover deleted contacts from Android phone? The answer is Yes. If you prefer one simple and safe way to make it, then one professional Android contacts recovery tool can be your first choice.
Tool We Use to Restore Deleted Contacts on Android Phone
PhoneRescue for Android is one professional Android contacts recovery tool that aims to help users find deleted or lost Android phone contacts in an easy and safe way.
1. All your deleted contacts will be easily recovered with contacts name, phone number, email, job title, address, companies and more.
2. Allows you to preview, select and recover the deleted contacts to your Android phone directly as per your needs. Or you can choose to save the deleted contacts as VCF, CSV or HTML to your computer.
3. Besides contacts, it also supports recovering deleted photos, messages, videos, music, etc. on your Android phone.
3. Compatible with all the Android devices, such as Samsung, HTC, Sony, Huawei, etc.
How about give it a try? Click here to go to PhoneRescue download page, please choose Android Data Recovery.
Also Read: How to Recover Deleted Photos from Android Phone >
Part 1. How to Recover Deleted Contacts from Android Phone in 1 Click
Step 1. Open the PhoneRescue for Android  > Connect your Android phone to Mac/PC computer via USB cable.
How to Recover Deleted Contacts from Android Phone – Step 1
Step 2. Select the files you want to recover like Contacts > Click Next. If you have rooted your device, the Deep Scan function would be available at once. If not, to start with, PhoneRescue will root your device. Rooting your device may take a few minutes. Please keep patient.
How to Recover Deleted Contacts from Android Phone – Step 2
Step 3. Choose the deleted contacts you need > Click Recover button.
How to Recover Deleted Contacts from Android Phone – Step 3
Part 2. How to Recover Deleted Contacts from Android Phone via Gmail
If you have synced all your contacts on Android phone with your Google account, then you can restore deleted contacts with your Google account. But it is worth mentioning that this way is only able to retrieve the contacts in the past 30 days.
Also, when you set up a time for getting back contacts, the contacts saved after the time you choose will be lost. So, you’d better export those contacts to your computer prior before starting the process.
Step 1. Log in your Google account on Google Contacts > Click More on the left panel > Choose Undo changes and a window will pop up.
Step 2. Choose a time and click “Confirm” to proceed > Tap “Google” or “Accounts” > “Google” > “Restore contacts”.
As you can see, PhoneRescue for Android is easy-to-use and it does not need you to have any technical knowledge. Click here to get it and recover your deleted contacts from Android phone without effort.
Member of iMobie team, an Apple fan as well as an anime lover. Like to share solutions on Apple related problems.
PhoneRescue® for Android
Recover deleted Android data and files with the highest success rate, and directly back to your Android phone or tablet.
  • * 100% Clean & Safe
5,716,299
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
based on 2243 Customer Reviews
