How to Recover Deleted Contacts on LG Phone
Don’t know how to recover deleted contacts on LG phone? Read this step-by-step guide to retrieve deleted contacts on LG phone easily and quickly.
By iMobie | Posted: Feb. 28, 2018, Last Updated: Feb. 28, 2018
Home > PhoneRescue > PhoneRescue for Android > How to Recover Deleted Contacts on LG Phone
Uninstall a bunch of apps, deleted some unneeded messages and duplicated contacts to make your LG smartphone run faster? However, you just deleted the important contact information accidently in the process and urgently need to recover them? If you are in such a case, then don’t worry. Now you are in the right place.
If you just deleted your LG contacts mistakenly, the first thing you should do is stopping using your smartphone in case the deleted contacts are overwritten by the new data. And then let a professional and safely LG data recovery tool to help you retrieve your deleted LG contacts.
Also Read: How to Recover Deleted Data from Samsung Tablet Easily >
The Tool We’ll Use to Recover Deleted Contacts on LG Phone
PhoneRescue is a professional iOS and Android data recovery tool. With PhoneRescue for Android, you can easily find both deleted and existing contacts on your LG phone.
How to Transfer Contacts and Photos from Samsung to iPhone
Step 1: Download PhoneRescue for Android on your computer, install and launch it > Connect your LG phone with computer via a USB cable.
How to Recover Deleted Contacts on LG Phone – Step 1
Before recovering your deleted contacts with PhoneRescue for Android, you need to root your LG device first.
Step 2: Select Contacts to recover > Click Next on the right > Click Deep Scan to scan your deleted contacts on LG phone.
Recover Deleted Contacts from LG Phone – Step 2
Step 3: After scanning, you’ll see the list of your deleted contacts > Choose the one you would like to recover > Click the button at the right corner to rover them to your LG phone directly or send them to your computer.
LG Contacts Recovery – Step 3
After the above introduction, you will know recovering deleted contacts on LG phone is such an easy thing. Moreover, PhoneRescue for Android is well compatible with Android system, so no matter which model of cell phone you own, LG, Samsung, HTC or Sony, it can always help you recover what you want. Why not download it to have a try?
PhoneRescue® for Android
Recover deleted Android data and files with the highest success rate, and directly back to your Android phone or tablet.
  • * 100% Clean & Safe
5,716,299
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
based on 2243 Customer Reviews
