How to Recover Deleted Data from Android Phone Easily & Quickly
Want to recover data from Android phone but do not know how? This guide will tell you how to restore deleted data from Android phone easily.
By iMobie | Posted: Mar. 01, 2018, Last Updated: Mar. 01, 2018
Home > PhoneRescue > PhoneRescue for Android > How to Recover Data from Android Phone
The unexpected always happen, like mistakenly delete important contacts or lose everything due to factory reset. It can be quite inconvenient no matter you lose some or the whole Android phone data. And is it possible to recover the deleted data? The answer is Yes. One professional Android & iOS data recovery – PhoneRescue can help you make it.
To ensure a higher rate of recovery, you’d better stop using your phone once the data loss happens. Otherwise, the deleted data can be overwritten by the new data and cannot be recovered.
Also Read: How to Retrieve Delete Contacts from Phone Memory >
Tool We Use to Recover Data from Android Phone
PhoneRescue for Android is one powerful recovery tool that can help users recover deleted data from Android phone in an easy way. It can help you find deleted contacts, photos, audio files, messages, calendar, videos and more. You can first preview and select the items you want to recover. It works perfectly with the latest Android OS and the most common Android devices, including Samsung, Sony, HTC, etc.
First, download PhoneRescue for Android to get the tool. And then follow steps below to make it with ease.
Step 1. Launch PhoneRescue for Android > Connect your Android phone to computer.
How to Recover Data from Android Phone – Step 1
Step 2. Choose the data you want to recover > Click Next. If you have rooted your device, the Deep Scan function would be available at once. If not, to start with, PhoneRescue will root your device. Rooting your device may take a few minutes. Please keep patient.
How to Recover Data from Android Phone – Step 2
Step 3. Preview and select the data you need > Click Recover button. You can choose to recover the data to phone or download them to computer.
How to Recover Data from Android Phone – Step 3
Can’t Miss: How to Recover Deleted Text Messages on Galaxy >
As you can see, you can recover data from Android phone easily and quickly. So why not give it a try to get your lost data back?
Member of iMobie team, an Apple fan as well as an anime lover. Like to share solutions on Apple related problems.
PhoneRescue® for Android
Recover deleted Android data and files with the highest success rate, and directly back to your Android phone or tablet.
  • * 100% Clean & Safe
5,716,299
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
based on 2243 Customer Reviews
