How to Reset Samsung Tablet with No Data Loss
Want to reset your Samsung tablet but don’t know how? Read on this guide to learn two simple ways to reset Samsung tablet without losing any data.
AnyTrans for Android – Helps You Transfer Data on Android with Ease
AnyTrans for Android – Best Android Data Transfer
Get AnyTrans for Android on your Mac/PC to transfer the important data on Samsung tablet to another devices for a backup, so that you can reset your Samsung tablet with no data loss.
Yesterday, my Samsung tablet suddenly decided to turn itself off when I was playing Clash of Clans. But I clearly saw that it have more than half charge on the battery. And in recent days, the apps act up all the time. I’m nuts about this, what do you think?
You may encounter the same situation like above users that your Samsung tablet not works perfectly like before. With time goes by, it is running slow, crashing or even becomes unresponsive. Actually, every moment your Samsung tablet acts up or any of these cases apply, it may be high time for you to hard reset the tablet. And here in this guide, we will show you two efficient & simple ways to help you quickly reset your Samsung tablet with no previous data erase.
Also Read: How to Transfer Contacts from Samsung to iPhone >
Part 1. Transfer Your Data to Computer for a Backup First
Before we start the reset process, you have to do the most important preparation first. That is to transfer your data to computer or SD card for a backup to ensure that you will lose nothing after the reset. And below are tutorial to lead you to transfer your precious data from Samsung tablet to computer in detailed steps. If you don’t need to back up your data, you can directly move to part 2 to reset Samsung tablet.
Step 1. Download and install AnyTrans for Android on your Mac/PC and launch it > Connect your Samsung tablet to the computer > Click Content to Mac/PC mode.
Step 2.  Check the file category you want to backup > Click on To Computer button to backup them to computer now.
Do not disconnect both the two devices to the computer until the whole transferring process is completed. It also supports you to transfer data between devices with different operating systems, including iOS, Android, WinPhone and Symbian.
Part 2. How to Reset Samsung Tablet via Two Ways
Method 1. Reset Samsung Tablet with Key Combination
Step 1. Press the Power key for a while to turn off the device > Hold and press the Volume Up + Home + Power button for a few seconds > Release the keys when see the recovery screen and the Samsung logo appears on the screen.
Step 2. Select the wipe data/factory reset by using the volume buttons and press the Power key to confirm > Choose Yes – delete all user data > Wait for a while and select reboot system now when the recovery mode appears again > success.
Method 2. Reset Samsung Tablet with Factory Reset
Step 1. Go to Settings > Choose Privacy in the middle of the list > Tap the Factory data reset option.
How to Reset Samsung Tablet with Factory Reset – Step 1
Step 2. Tap Reset Tablet button > Touch Erase everything button to confirm> success. The Samsung tablet will take a few seconds to erase everything, and then it will restart automatically.
We hope you find this guide useful. If you have any issue on how to reset Samsung tablet then comment below to let us know and we will reply you as soon as possible. Also, questions about the Android data transfer tool are also welcomed. Get more from AnyTrans for Android >
Thanks for your reading about and interests in AnyTrans for Android. AnyTrans for Android is a professional Android data management tool, which enables you to transfer, backup, manage Android contents as easy as ABC. It will be available soon on Jan.2nd, 2018. Please stay tuned!
