How to Transfer AVI to iPad without iTunes
How to convert and transfer AVI to iPad without iTunes? This post tells you one easy-to-use transfer tool to quickly make it.
AnyTrans – AVI to iPad Transfer Tool
Download AnyTrans to easily convert and transfer AVI videos from computer to your iPad Pro/Air/Mini without erasing your device, ready for iOS 9.
Before a long journey, you may want to get some videos to your iPad to play on the way without a Wi-Fi connection. However, you may have found that you couldn’t add AVI to your iTunes and sync them to your iPad. And you may have tried some other methods to transfer these AVI files to iPad without using iTunes, such as DropBox. And finally, you dropped out because you found that it is super slow to use these online services to transfer a large AVI video.
Don’t Miss: How to Fix iPad Won’t Sync with iTunes
Don’t worry! In this post, we offer you an easy-to-use transfer tool - AnyTrans to directly transfer iPad un-supported videos from computer to your iPad.
About AnyTrans
AnyTrans is one perfect iPhone iPad manage which you can use to transfer videos between your iPad and your computer, no matter in Macintosh or Windows system. And while transferring, it will convert iPad unsupported video format to be supported one. More about AnyTrans >>
How to Transfer AVI to iPad with AnyTrans
The process to transfer AVI from computer to iPad is very simple. And it needs you only 3 steps to finish the transferring, and the transmission time depends on the size of your AVI files. Below, we show you the steps and screenshots.
Step 1. Download AnyTrans to your computer, install and run it. Connect your iPad to computer.
How to Transfer AVI to iPad without iTunes – Step1
Step 2. Scroll down on the homepage > click Videos > Movies.
How to Transfer AVI to iPad without iTunes – Step 2
Step 3. Click "+" at the top-right corner, find the AVI files you want to transfer and click "Open" to transfer them to your iPad.
How to Transfer AVI to iPad without iTunes – Step 3
You can use the top-right menu bar at the above screenshot to manage your iPad videos by deleting videos, transferring them between iPad and computer, and between iPad and another iOS device.
With AnyTrans, you can easily convert AVI to iPad supported file format, and transfer them to your iPad Video app in 3 steps. And beyond that, you can also use it to transfer some other data type, such as photos, songs and contacts. So, why not download it and have a free try?
What's Hot on iMobie
- How to Play AVI on iPad Pro/Mini/Air – This tutorial tells you how to play AVI videos on your iPad by converting them to your iPad. Read More >>
- How to Transfer from iPad to Windows PC – Read this post to know the method to get files from an iPad to a Windows computer. Read More >>
- How to Delete Videos from iPad – This guide offers you 2 methods to easily and quickly remove videos from your iPad. Read More >>
- Transfer Photos from iPad to Flash Drive – There is one tool you can use to easily transfer pictures from iOS device to Flash Drive. Read More >>
