How to Unroot Android and Reset System Status to Official
Looking for ways to remove root from your rooted Android phone or tablet? This guide will share you 4 simple methods to help you unroot Android safely.
By Bella Miller | Posted on: Sep. 28, 2018, Last Updated: Sep. 10, 2019
Rooting is one of the greatest advantages that Android users have to use plenty of features on their phone. But, this advantage comes along with one major risk, i.e. phone warranty. Rooting completely voids your phone warranty. So, if you are seeking the ways to unroot Android phone so that you can have your phone warranty back, then refer to this guide. Here we have mentioned four reliable ways to unroot Android phone.
PhoneRescue – Best Android Data Recovery Tool
This professional Android data recovery tool can help you recover deleted data from Android phone easily, including photos, messages, contacts, videos, etc.. If you accidentally lost some important files after rooted your Android phone, Free Download it to get them back in minutes.
Top 4 Ways to Unroot Android Phone
Method 1: Using ES File Manager
To unroot Android phone, you need a File Manager with root access. The ES File Manager is the best one to unroot your Android phone by deleting some files from your phone. If you do not have ES file manager on your phone, install it from Google Play Store.
Step 1 First, enable “Root Explorer” from the menu. Now, navigate to your phone main drive and search for “System”. Then, click on “bin”.
How to Unroot Android - ES File Manager
How to Unroot Android – ES File Manager
Step 2 From the “bin” folder, delete “busybox” and “su”. If these two files are not present in the bin folder, then select “xbin” from “system”. If you see these two files in this folder, then delete it.
Step 3 After that, navigate to the “system” folder. Then, choose “app” and delete “superuser.apk”.
Step 4 Finally, restart your phone and your phone will back to unroot state.
Method 2: Using SuperSU
SuperSU is a powerful tool to deal with rooted devices and it is a very effective tool to control all root settings on your phone. Many Android users install this app on their phone after rooting because of its useful features. With the help of SuperSU, it becomes easy to control rooted device. It allows users to unroot their phone easily. Follow the below instructions for how to reset system status to an official with SuperSU.
Step 1 To commence the process, launch the SuperSU app on your phone.
Step 2 Thereafter, navigate to the “Settings” tab. Then, scroll down and choose “Full Unroot” option.
Step 3 Now, the process to unroot phone will begin and after a few minutes, your phone will be unrooted and will be back to the original state.
Method 3: Using An App
If the above methods fail to unroot your Android phone, then you have another option which is using a free app. There are plenty of apps available on the Google play store to unroot Android phone. The best one that you can use is Universal Root. This app is completely free to use. However, Samsung Galaxy devices which are from 2013 and later may not work properly with this app. LG devices will be able to unroot, but it still shows rooted because of LG’s eFuse.
Method 4: Through An OTA Update
By installing an OTA update on your phone, you can unroot Android phone, as software updates break the root access on your device. For this method, you need to uninstall all the rooted apps on your phone such as SuperSU. After uninstalling all rooted apps, then update your phone software. If the next update does not arrive, then wait for its next update to remove the root access.
Now, you have got a perfect solution on how to unroot Android phone. You can use any of the above-mentioned ways to bring back your phone to the original state. If you find this guide useful, just share it.
Bella Miller
A senior editor, an Apple fan at iMobie Inc.. I love both dancing and helping users to solve iOS & Android related issues by writing various types of tutorials.
PhoneRescue ® for Android
Recover deleted Android data and files with the highest success rate, and directly back to your Android phone or tablet.
  • * 100% Clean & Safe
5,716,299
Users Served
