How to Use Control Center without 3D Touch on iPhone iPad in iOS 11
Want to know how to use Control Center without 3D Touch on iPhone iPad in iOS 11? Follow this guide to grab a step-by-step tutorial.
Aug. 07, 2017
PhoneRescue - Easy-to-Use iOS Recovery
PhoneRescue enables you to get back deleted, lost, or disappeared iOS data and files quickly, from device itself, iTunes backups, and iCloud backups.
iOS 11 has redesigned Control Center with more functions. You can customize it as what you want and need. However the most remarkable, and shocking feature is that iOS enables Control Center of all devices to work in their full-fledged form, even those without 3D Touch. That means you can get the best out of Control Center even without 3D Touch on your iPhone iPad running iOS 11. You must wonder what exactly we can do to realize using Control Center without 3D Touch right now. No need to worry. We will describe it in the following step by step.
How to Use Control Center without 3D Touch in iOS 11
1. Download and install iOS 11 on your iPhone iPad.
2. To enjoy this awesome feature you need to Enable Access Within Apps in Settings > Control Center to have your device respond to that gesture when you’re using an app, if you don’t have 3D Touch on your gadget.
3. Swipe up from your display’s bottom and you’ll get to iOS 11 Control Center on iPhone without 3D Touch. iPad users can double click on their Home button to perform the same action.
4. Click and hold the shortcut buttons. You can access Music, Wi-Fi, adjust the brightness of the screen, get your alarm, Mobile Data and many other features.
5. Once you choose the button and press-hold it you’ll see a shortcut menu above it. This is how you can perform various tasks if you don’t have the 3D Touch taptic engine.
You will not receive the haptic feedback since you don’t press the 3D Touch button. But you’ll feel like using this option since you can get to various options within iOS 11 Control Center.
If you still have iPhone 6 and don’t want to update to iPhone 6s with 3D Touch, 7 or upcoming iPhone 8, you can use the new iOS 11 technology to use Control Center without 3D Touch on iPhone iPad.
Join the Discussion on iOS 11 Upgrade
