How to Use Paste and Go in Safari on iPhone iPad Running iOS 9
This post shows you one of the new features of iOS 9 – use Paste and Go in Safari on iPhone or iPad running iOS 9.
Oct. 08, 2015
PhoneRescue – Recover Safari History on iPhone iPad
PhoneRescue – Best iPhone/iPad Data Saver
Download PhoneRescue to have a try so that you can recover your lost iOS data easily. Now read this guide on how to use Paste and Go in Safari on iOS 9 devices.
Safari is the default browser of Apple products (iPhone/iPad/Mac), and in the new operating system iOS 9, one of the nifty features is the ability to quickly paste a URL and submit it in Safari. It requires that a user have the link copied to the pasteboard. This new feature greatly saves users’ time and energy. Now follow this tutorial to know how can you use Paste and Go in iOS 9 Safari.
Also Read: How to Recover Safari History on iPhone/iPad >
How to Use Paste and Go in iOS 9 Safari
Step 1. Just copy a URL or text into your pasteboard, and go to Safari on your iPhone or iPad. Tap and hold on the address/search bar in Safari. You should now see the address bar turn a darker shade of grey, followed by the iOS copy & paste menu.
Step 2. The copy and paste menu will automatically show you a Paste and Go or a Paste and Search option, which depends on the contents you have copied to the pasteboard. If you have a URL copied to your pasteboard, you’ll see a Paste and Go option. If you have general text, you’ll see a Paste and Search instead.
Step 3. Tap on the Paste and Go or Paste and Search, and Safari will show you the content you need. If these new options not appear, make sure that you’re tapping and holding on the address bar directly.
You May Like: The Possible Problems and Solutions of iOS 9 >
If you want to view Safari History or Safari Bookmarks in iTunes or iCloud backup, you can download PhoneRescue to achieve that. It is a professional iOS data recovery and backup extractor that allows you to view and recover data from iDevice, from iTunes or iCloud backup easily.
If you want to learn more info on iOS 9, please refer to Complete Guide for iOS 9 Update. If you lost some data on iPhone, iPad or iPod touch during the updating process of iOS 9, you can download PhoneRescue to get them back.
