Top 5 iOS 12/12.1 WiFi Issues and the Possible Fixes
You can experience iOS 12 WiFi issues both at home and at work. Connecting to one of the many free WiFi networks may also end up in disrupted WiFi calls or slow transfer of data. Here we provide you with a detailed guide on how to deal with iOS 12/12.1 WiFi issues and restore your WiFi functionality.
By iMobie | Posted on: Sep. 17, 2018, Last Updated: Nov. 05, 2018
Home > AnyTrans > AnyTrans for iOS > Top 5 iOS 12 WiFi Issues and the Possible Fixes
As you know, iOS 12 is out now! As the first enhanced version, iOS 12.1 is available as well. Some of our users report problems of various types, WiFi issues are included. The overwhelming majority of iOS 12 users cite WiFi problems occurring after an iOS update or after updating third-party apps. Other users are finding their iOS 12 WiFi is slow after an update or end up with iOS 12 WiFi that turns on by itself after tweaking certain settings.
In the below paragraphs, we list the 5 most common iOS 12/12.1 WiFi issues and provide possible solutions to each of the listed WiFi problems.
Problem 1. iOS 12 WiFi Keeps Turning on by Itself
You should be aware that in iOS 12 or iOS 12.1, WiFi and Bluetooth will still be available after you disconnect from WiFi accessories. It is made this way for you to be able to continue using services such as location, Instant Hotspot, Apple Watch and others.
Therefore, you may see that your iOS 12 WiFi turns on by itself after you have disconnected from a network. Follow the below steps to completely turn off WiFi.
Step 1 Go to Settings and select WiFi.
Step 2Turn off WiFi using the slider.
Problem 2. iOS 12 WiFi Keeps Dropping on iPhone/iPad
You can see your iOS 12 WiFi calling not working if the network transmits a weak signal or if you have coverage troubles in certain locations. Follow the below steps to check the WiFi availability.
  1. Go to Settings and select WiFi.
  2. Check if WiFi is on.
  3. Tap on a WiFi network to join.
  4. Enter the password, if asked.
  1. Unplug your router or modem, and then plug it back in.
  2. Restart your iOS 12 device and check the WiFi network.
Problem 3. iPhone/iPad Not Connecting to WiFi
Step 1 If you have iOS 12 WiFi issues that prevent you from connecting to a WiFi network, you should first check whether your device is detecting a problem.
Step 2 When iOS 12 is detecting an issue with a WiFi connection, you will usually see a WiFi recommendation under the name of your WiFi network.
iPhone Not Connecting to WiFi
Step 3 Tap on the WiFi network to get more information about the issue and act according to the prompt message.
Step 4 Restart your device or check if you have WiFi coverage in your area.
Problem 4. iPhone/iPad Unable to Join Network
On some occasions, your iPhone or iPad may experience iOS 12 WiFi issues that prevent you from joining a network. You can usually return to normal operation after you restart the device or reset your network settings.
Step 1 Tap to join a WiFi network.
Step 2 Enter your WiFi password if asked.
Step 3 If the “Unable to join the network” or “incorrect password” warning pop up, please restart the device.
iPhone Unable to Join Network
Step 4 Try to enter your password again.
If the restart does not work, try to reset your network settings. You should be aware that by resetting network settings, you also delete stored Wi-Fi networks and passwords, cellular settings, and VPN and APN settings. Backup any settings before the reset.
Step 1 Go to Settings and select General.
Step 2 Select Reset and tap on Reset Network Settings.
Step 3 Enter your password if required and confirm the reset.
Problem 5. iOS 12 WiFi Is Slow
If you see your iOS 12 WiFi is slow you can first try restarting your device and reconnecting to the network. Any of the above fixes may also help you establish a faster WiFi connection.
Nonetheless, you should know that wireless interference could cause slower performance or disconnection from your Wi-Fi network. Many sources of interference can slow down your iOS 12 WiFi connection and below we list the most common items that may interfere with your WiFi:
Try to place any of these devices and items as far as possible to avoid the interference with your iOS 12 WiFi connection.
The Bottom Line
That’s all for the possible fixes for the iOS 12/12.1 WiFi issues. Hope your problems will be resolved. And if you find any other useful tricks to the issue, welcome to write them down in the comments below to let more users know.
AnyTrans ® for iOS
  • * 100% Clean & Safe
11,452,517
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
